Does it run all time? What are the symptoms? You could have your thermostat wires touch together and it will cause the unit to run all time. Your thermostat wire runs from the inside of the furnace to the thermostat and from the outside to the thermostat may want to check the wire all the way from units to thermostat, I can't understand your problem need more information.
Sounds like either a bad thermostat or a loose wire...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
