True Technogym Excite Run 700 Treadmill Logo
g
ginger Posted on Jun 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Technogym no power to display
Hi. Inverter has power but no power to control dash.All fuses are ok. please help!!!!!
John Ritchie
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Jun 13, 2014
John Ritchie
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
23581
Points
28
Assuming all the cables are ok, your display is probably dead and needs repaired. But more often than not the inverter is the problem.
If you have a way to swap it with another Technogym inverter I would try that first.
Alma chee
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on May 28, 2015
Alma chee
Expert
Level 2:
New Friend:
Answers
69
Questions
0
Helped
81814
Points
161
For a replacement inverter please see this website:
http://www.partsfortreadmill.com/catalogsearch/result/?q=inverter
1helpful
Technogym recline bike 500
If the lights on your Technogym Recline Bike 500 turn on but the other settings on the display do not work, there could be a few possible causes for this issue. Here are some troubleshooting steps you can take:
  1. Check Power Connection: Ensure that the bike is properly connected to a stable power source. Double-check the power cord connections and ensure that they are securely plugged into a functioning 220V power outlet.
  2. Power Cycle: Try turning off the bike and unplugging it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This can help reset the system and resolve any temporary issues.
  3. Check Display Connections: Verify that all cables and connectors related to the display are securely connected. Inspect the connections for any signs of damage or loose connections. Ensure that the cables are properly inserted into their respective ports.
  4. Reset the Console: If the issue persists, try resetting the console or display unit. Refer to the user manual for your Technogym Recline Bike 500 to find specific instructions on how to reset the console or perform a factory reset. Typically, this involves accessing the settings menu on the display and selecting the appropriate reset option.
  5. Software Update: Check if there are any available software updates for your Technogym Recline Bike 500. Visit Technogym's official website or contact their customer support for information on firmware updates. Updating the software may resolve any known issues or bugs affecting the display functionality.
  6. Contact Technogym Support: If the above steps do not resolve the issue, it is recommended to contact Technogym's customer support directly. They have access to specific troubleshooting steps and can provide further guidance based on their knowledge of the Recline Bike 500. They may be able to diagnose the issue remotely or recommend further solutions.
When contacting customer support, provide them with detailed information about the issue, including any error messages or specific symptoms you are experiencing. This will help them provide more accurate assistance and advice.
Remember to follow safety precautions and consult the user manual for your specific model when attempting any troubleshooting steps or maintenance tasks.
1helpful
Technogym Run 70. Equipment Blocked Contact Technical Support20
Here is there Support. Contact is at the bottom of the page.
Technogym Customer Support
Technogym https://support.technogym.com Technogym Customer Support is where you will find all the answers to your frequently asked questions, articles and useful resources to help you to get the ...
I also found this
A message stating 'the equipment is blocked' essentially means that a problem was detected that *might* be a blockage against moving of the moving parts. This commonly can be owing to two things:
1. the upper and lower assemblies (i.e the upper is the console, the lower is the electronics or boards in the lower part of the treadmill, e.g. the motor controller board and brake board) have a fault in the communication between them. This indicates first that you need to check the cable between console and lower assemblies, and also to re-seat either end, or at minimum make sure there is no breakage or crimping in that cable or wire harness, between console and lower assembly and lower boards.
or
2. the error was detected by the brake board, and one must go through the error procedure for a brake board error.
(In some models, (2) requires accessing the Low Kit Menu, to see whether there is a genuine error registered in the Low Kit Fault area of memory.)
Also
3. you might unplug it from power while it is On, and see how that works, after about 2 hours unplugged, please.
2answers
When I turn on my whistler 1200 power inverter the light above the power switch turns red and no power to 110 outlets. What does this mean? How do I fix it?
Please use the initial setup process to double check that you've not accidentally pressed a button and allowed the current issue. After you've redone the setup, please attempt to use your inverter again. Thank you.
WHERE ARE THE FUSES ON THE TECHNOGYM 700
No matter which piece of Technogym equipment you have with 700 on it, the fuses are on, or at the power supply board inside the machine. near the end of the AC cord. If a fuse has blown, something caused it to. Remove the cause before replacing the fuse.
The HVAC climate control display isn't working. The fuse inside is good. Where do I check nesxt?
Hi Anonymous, Randy here I 'll see if I can help you with your problem. By chance have you Looked under the hood in your engine bay on the fender there should be a black box, this is the Power Distribution Box it contains Fuses, Relays, etc. This carries the Higher load fuses and such. Please let me know what you find, Hope this helps and Good Luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/randall_d932ef6e01588b0f
2answers
Treadmill display problem
The equipment is blocked... (2) this is the message I get in my Run excite 700 technogym treadmill.
Can some one help.
Thanks a lot
2answers
Technogym Run Excite 700 Schematics
Dear John
Please find here in attachment the schematics for the lower kit/board for the Technogym Run Excite Treadmills.
We would be very happy to help you. So, can you please tell us where do you come from? We will put you in contact with our local customer care.
Thanks
Technogym Staff
2answers
I got 98 GMC Envoy there no power to A/C fan control, 4x4 switch, temperature gauge and fuse gauge,I'm try to sawp the fuse and relay under the hood and check under dash fusebox alls fuse ok but
if there have some problem on your A/C, may be the Multi-Diag Access J2534 can help you. It has the function for air condition, such as Diagnosis of cooling electronic,
Reading settings cooling circuit,Test servo actuators
http://www.allobd2.com/wholesale/[email protected]
I own a 1999 Mercury Grand Marquis and I need some help. With the headlight switch in the off position all dash and display lights including the digital clock work fine, but the display on the radio and...
There are two 15amp fuses marked 4 and 8 that provide power to the light control module. If those fuses are good, and those circuits have power, the problem may be with the control module. The module provides power to the dash lights.
You may need a shop to trace the circuits and find the problem.
Top True Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a True Exercise and Fitnes Expert? Answer questions, earn points and help others
