Pioneer VSX-823-K Logo
D
DURK Posted on Jun 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO STOP ADDVANCE MC ACC LIGHT FROM FLASHING?
ADVANCED MC ACC LIGHT FLASHING. PSE ASSIST
Steve K
Level 3:
Genius:
  • Pioneer Master 1,054 Answers
  • Posted on Jun 13, 2014
Steve K
Pioneer Master
Level 3:
Genius:
Answers
1054
Questions
0
Helped
574179
Points
2865
Your unit is in protect mode. Try pressing and holding the power and advanced surround buttons. This should turn it on. If it shuts right back off, then you probably have a short in the amp that needs to be repaired.
On 92 Dodge Dakota V6, 2 wheel drive. If the power assist unit is leaking does that mean the master cylinder is bad too?
3.9L V6
LEAKING DOT4 IS , NOT ALLOWED EVER
BUT YOU ONLY SAID THE WORD LEAKING, NOT WHAT IT LEAKED
WE DO (vacuum leak down) TESTS ON THE BOOSTER BEHIND
THE MC, AND THERE IS NO FLUID IN THE BOOSTER ever.
.SO fluid LEAKS ARE ALWAYS MC BAD, END STORY.
OR LINES RUSTED TO mc OR LOOSE LINE FITTINGS TO IT.
THE BOOSTER IS ONLY A VACUUM DEVICE,.HERE. PURE!
VACUUM BOOSTER ASSIST.
fix leaks first, find the source an fix it first.
bleeding is JOB last on brakes.
and last last is silly lamps, that many need reset.
and ABS will now have a ton of air on its inputs and hard to get out.
but i bet you knew that and to read the service manual
the factor did use pressure bleeding to make the car new.
(fast and sure ) my jeep has ABS bleed cycling mode.that helps.
the MC rear seals love to fail and leak flue
the inside MC seal fails is never fun to find. and unbalance brakes is never going to make ABS happy here if true.
leaking mc is really great thing,it yells I AM BAD
unlike inside wear.
no 30 year old MC is good. so there is that too.
My Wizord 4 electric fence energiser service light and alarm comes on? Can you advise pse?
Flashing service light usually means the battery might be going bad. Also, check the fence for any branches or grass making contact.
2answers
My 1994 isuzu 250 brake went hard i replaced the pipes new booster new altenator with pump now brakes is better but when i am in traffic stop go after while no brakes please hel
no country stated, no car stated.
no engine stated, petrol or diesel.
below is my wild and useless guess ,its petrol.
Power assist brakes work off a base of manual brakes.
my wild guess 2 is KB truck, in Africa
this next line means with booster off line
(hose plugged, and pulled)
do the base manual brakes work or not.??????????????
this is first. and a big safety issue.
is this hard to understand.?
is this your first brake job?
how the manuals work 101:
using up to 100 lbs of (man) force on the brake pedal; can get you 600 psi force at the rear of the mc, (and 4 time more at front calipers)
the pedal is 6:1 ratio, (approx)
the MC piston to the slaves (ratio) the front caliper pistons are huge (4:1), and 6x4=24:1 total . 24x100 is 2400 lbs, from you foot to pads.
the cars stops great like this.
assist only lighten the pedal load, needed.
allows 50 lb girl to drive car, or my pet chimp.
or old skinny grand ma , to church...
these facts are why the brakes still work in manual mode.
The stopping distance does not decrease with boost.
(granny excepted) one could call this granny assist.
see, in a shop full of men we can stop the car
fast and same low distance.
my guess is your post is about assist only.
not brakes dragging
not braKES WEAK.
assist is a whole other set of issues, if only assist fails....see?578fb15a-cb47-464a-8d9a-701f0cf1da4e.jpg
Pioneer SC LX73 MC ACC Light flashing blue and unit will not power up have looked at fuses CheersBrad
Don't have any info on that particular model, but on other pioneer receivers that means the unit is locked into protect mode. It sensed something wrong with the amp and shut itself down to try and avoid damage. You can try and reset it. Most likely button combination is holding the 'advanced surround' button and power.
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
3helpful
I have a omron ear thermometer mc-510 and when i press the on button it keeps flashing AA can you tell me why
AA is displayed when there is a sudden ambient temp change. Leave the mc-510 out of its case in the room where you are going to use it for 5 minutes and try again. here is a link to the instruction manual www.omron-healthcare.com/export/.../IM-MC-510-E2_02-08-08-EN.pdf
2helpful
3answers
My 01 chevy malibu theft deterrent light is on and my car wont start or let me get my key out of the ignition what can i do?
turn the key to the "acc" position. you will notice the theft light flashing. leave the key in this position for exactly 10 minutes. the light should stop flashing. turn the key back to the off position and then start the car as you normally would. Works every time!
1helpful
Ml500 mercedes service and engine lights on dash on not time for service yet. i want to reset it with buttons in car .pse assist
If you are having a Check Engine Light, then there is something wrong and you need to have it checked.
As for the service indicator, then follow the instructions int eh car owner manual for resetting.
Dlp tv problem
Is the lamp light the only one thats flashing? Does the buzzing your hearing stop or is it constant? Also when you press power off does the buzzing stop instantly or continue? Respond to this post and I will try to assist you. Is HL-R677w the correct model number also?
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
