Question about Edirol V4 Mixer
For an EDIROL V4 video mixer, which buttons must to be pushed before turning on to do a factory reset?
I want to do a reset because there's a troubleshooting: All works except the effects and transition button, and the output preview button. I've tried the menu reset but it does'nt fix the problem. Thank you.
  • Robert Roig
    Robert Roig Jun 14, 2014
    Trying randomly I've found that by pushing (and keeping pushed) some buttons before switching power on, that opens different sub-menus: the Test menu and the Help Menu.
    Combo Buttons:
    - PREVIEW 1+2+3
    - MENU + ENTER
    In the Help Menu it is said that for an All Reset the buttons are:
    MIX + BPM (it appears written BMP but it's probably an error and means BPM sync button)
    Top Expert:
  • Edirol Master
  • 3,698 Answers
Www.roland.com/support/article/?q=manuals...V-4
Posted on Jun 13, 2014
How to reset yamaha htr -3066
With unit in standby, hold down the Tone control button and the Info button at the same time. While they are being pressed push the power button. The unit will turn on in service mode. Hit the BD button repeatedly until you see S3. This is the factory reset. Press the CD button repeatedly until it says Preset Reserved. Press the power key and the unit will be reset to original factory specs. Good luck to you.
Jun 01, 2016 | Yamaha Audio Players & Recorders
A Samsung V4 Digimax. The lcd screen won't show images or take photos? Help Terry Hilsz
It indicates that your ccd image is defective .
How old is your camera ?
Also check the settings .
Reset to factory settings by pressing the reset button( present in most models ).
Oct 06, 2008 | Cameras
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
I HAVE PROBLEM WITH MANUAL HANDLE NOW I ONLY USE AUTO TAKE .. WITH MY EDIROL V4
The potentiometer has probably failed... You can TRY putting a bit of CRC226 which is available at HomeDepot in the electrical dept. into the slot and working it. Use only that product as there are other CRC products there. About $2.70 in a small blue aerosol can. Use the spout, spray into the center and move handle. repeat a few times. If that doesn't' work, replace the pot.
Apr 01, 2011 | Edirol V4 Video Mixer With Effectsships...
VERTICAL BLUE LINES ON PS3
You could try a video reset on the ps3 or a factory reset. The factory reset will erase all data on the unit, the video reset will now.
The video reset is done by pressing and holding the power button for 3-5 seconds from a power off state, the unit will beep 1 time indicating the video is reset.
Here is how you do a factory reset:
This will wipe all the saved games and data from the machine but I have found it to correct most issues with the ps3.
You will need to push the power button to turn on the unit, but keep the power button held down for about 30 seconds. You will hear a beep (resetting the video settings), then 2 more beeps. After the 3rd beep you can let go of the power button and it should take you to the set up screens like you just got it out of the box.
You will lose everything you have saved doing this but it seems to make the system run just like out of the box again. If this does not fix the problem then it most likely is a hardware issue and may need serviced or replaced.
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
How to reset sony str-dg800 to factory settings
For the STR-DG800 you need to power off. Then hold power button 5 seconds. When "push entrer" appears on display push "memory/enter" button. System will turn off and reset.
Nov 17, 2010 | Sony STR-DG800 Receiver
I have a behringer ddm4000 mixer and my problem is when i turn it on it tells me on the screen to adjust vr 24 ive pressed every button and nothing is working???
Just reset your unit to factory default setting,so it will back to it's original setting.
Hope it may helps you;
Regards;
VOTIT
Nov 26, 2008 | Audio Players & Recorders
Edirol R-09 Recorder Controls Frozen
This is a PARTIAL solution...
I've found that if I partially remove the SD-Card, then push the power button, it then starts and continues (without freezing) to show the meters and shows "no-card", then I push the SD-Card fully and it then shows "Loading"...
From there, it can be operated. But if I try to power-up with the SD-Card installed, it freezes and ceases to obey any buttons; which requires to remove the batteries to turn it off.
Please be aware that removing OR installing the SD-Card with power-on is NOT recommended, BUT is THE ONLY way my R-09HR now can be operated. I'm contacting the factory to solve this, but in the mean time, I had to record a live concert that I had promised to get recorded, so I tryed everithing and discovered the reinstallation of the SD-Card as the only thing that allowed me to get that concert.
The SD-Card that I bought for my R09HR is a Kingston 16GB. good luck, give it a try.
Sincerely, amclaussen at amarquez@imp.mx
Sep 09, 2008 | Edirol R-09 Digital Voice Recorder
Factory reset
put a paperclip in the front just below power button and turn unit on. this will factory reset it.
Oct 25, 2007 | Polycom VSX 7000 Video Conference
Edirol V4 Mixer Logo
195 people viewed this question
Top Edirol Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you an Edirol Video Camera Expert? Answer questions, earn points and help others
