Water dumps onto floor instead of collection receptacle
SOURCE: no water in tank
I have had two LG Dehumidifers in my show and the customers said the same thing it runs but no water in the bucket. Yes when they started them up the compressor came on but not the fan. Both had tight bearings. Lubricating the bearings but the motors were bad.
SOURCE: LG LD65EL dehumidifier will not collect water
Make sure the filter is clean and also make sure the coils are cleaned. If these are clogged they will restrict airflow which will cause the coils not to remove the humidity from the air. LG recommends that you clean the air filter every 2 weeks. They also include a brush to clean the coils. If this still does not work you will need to contact LG for service or a replacement. They have a 5 year warranty on them so the ones that you guys have should still be under warranty. Make sure that you have your reciept when you contact them to prove that it is still under warranty. Keep me posted. Also please rate my solution when you get a chance. Thanks - Tech101
SOURCE: water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
SOURCE: My LG (LHD45ELY6) dehumidifier turns on OK. I hear
Bring it back for warranty and they will send you a new one. The warranty is 5 years for everything. These LG units have a defective design and I was told the evaporator (or parts thereof) rust and leak. My repair store had rows of LGs in for repair. Most people avoid the hassle and buy another brand. If you have the time to call LG, bring it to a repair shop, wait for an assessment, call back LG for a replacement, you'll get a replacement. But you may have to do it all over again next year -- and until your warranty expires.
SOURCE: LG45EL dehumidifier no longer collects water.
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
There
are many reasons why a dehumidifier will not work or collect water.
Here
Dehumidifier
heatman101
