Dial your voicemail, put in your password, after you are in the voicemail, press 8 and listen to the prompts, it will tell you were to record your name for the company directory.
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
To access your voice mail remotely, call into the voicemail and wiat for either the main greeting or your mailbox greeting to answer the line, press ** followed by your mailbox number password and then the # key (ex. **2251234#).
If your trying to get your messages from another nortel set in the office press your open voicemail button or feature 981. The left soft key below the screen should say OTHR. press the soft key the screen should change to LOG: enter in the mailbox number followed by the password and #.
If your trying to get your messages remotely, call into the office and when the auto attendant answers, press ** followed by your mailbox number password and #.
From your set, dial:
-> FEATURE 9 8 1 -or- the voicemail key
-> Put your password in
(if this is a new install 0 0 0 0 is your temporary password)
-> You'll hear your name and how many messages you have
-> now press the number 8
Pressing 8 is to get into the adminsitration of this mailbox, and listen to the prompts.
This is where you can change the password, name, greeting. You want to change your primary greeting.
Good Luck!
It sounds like both phones are set to ring on incoming calls and both phones are set to call forward to voice mail box with the same amount of rings . you should turn off the ringing for both phones that way it will not jump between the to mail boxes . now when a call is trans it will go to the box .
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
