SOURCE: Bosch WVF 2402 Washer Drier Steam Problem
Hello All
Problem solved by clearing out the condensate container which on inspection was full of dried up fluff and dead tissues! This is not a ****that is mentioned in the manual and access to the bin is pretty tricky so I suspect there are lots of machines out there with the same problem waiting to happen.
Access was gained by taking the top of the machine off, removing the dryer motor and then scraping out the muck using a wire coathanger and a vacuum cleaner.
Many thanks
Andy Wray
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
SOURCE: my Bosch WVF 2402 will not drain
Tyere should be a filter located at the bottom right front of washer, behind a drop down cover.
Unscrew anti-clockwise to remove and clean.
SOURCE: I have moved in to
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
SOURCE: Need an instruction book urgently
For operating guides
or Service Manuals
try
www.mauritron2.com
