Before going any further or attempting to run it again. If you have not already done so. Inspect your vent tube. Insure that it is not clogged crimped or damaged. It sounds as if something is preventing the dryer from venting properly.
SOURCE: Our dryer is beeping and
I found via a Google search that E68 means one of the keys is jammed. Looking at it, it was pretty obvious which one, so I pushed it in and re-centered it in its casing. That did the trick.
SOURCE: frigidaire affinity dryer problem
message "ad" showing on my affinity frigidaire, anything wrong with this?
SOURCE: error code E4A on my
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
SOURCE: Frigidaire Dryer only runs on "low Heat" setting
Mexitronics
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
