Open thermistor in the fuser. Clear the code from service mode.
P * C * then 14 - Start then Yes then CA
If the code comes back you must clean toner off the thermistor, or replace the thermistor or the fuser.
This indicates a problem with one of the thermistors in your fusing unit. You will need to replace, clean, or check your themistors and then use sim 14-1 to reset the error code.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
It means that the thermistor in the fusing unit is open
which could indicate that it may have become faulty or is because of power fluctuations, a simple crop 14 reset should remove the error, but if it returns it should be looked at by a qualified sharp technichian
SOURCE: System error (f2-04) for Sharp Copier, model AR-M201
It is copy lamp error.
1- check the copy lamp on with sim.
2- replace the power unit.
3- replace the inverter.
4- replace the mcu pwb.
- Toner supply abnormality caused by
installation of unpacked toner cartridge
