My dell won't send a signal to the monitor. lights 3 an 4
Hello
what this means the memory sticks have an issue.
Try re-seating the sticks in your computer.
click on this link page 18 will show you how with pictures.
http://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-5150x_Service%20Manual_en-us.pdf
**Attenion!!! UNPLUG THE COMPUTER POWER CABLE!
ok .Remove and reinstall all memory modules to ensure they are seated properly. While you're doing that, it's a good idea to clean the contacts on the memory module. Close the computer and power it up. If you get the same 3 and 4 lights try this:
Removing the modules one by one from motherboard. This is simplest method for isolating a failing module, but this may apply only if the motherboard have more than one module on the SIMM or DIMM Slot. By selectively removing module one at a time from the system and then running the test you will be able to find the bad module very quickly. Be suRemoving the modules one by one from motherboard. This is simplest method for isolating a failing module, but this may apply only if the motherboard have more than one module on the SIMM or DIMM Slot. By selectively removing module one at a time from the system and then running the test you will be able to find the bad module very quickly. Be sure to mark the module that passes or when it test fails.Sure to mark the module that passes or when it test fails.
maybe its a bad memory stick
or
the slot where the memory connects is bad so that means the Motherboard will have to be replaced.
hope that was helpful
SOURCE: Dell 5150 - solid amber light at the switch.
Make sure the 12v power connector is securely connected to the system board. If you open up your computer look at the end of the board that the memory modules are there is a 4 pin connector thats the 12 v Make sure thats plugged in and secure, If thats ok you have already did the removal of the memory and replaced them, take out any pci express cards and use your onboard video, if that don't work try one memory module at a time see if that works you already seem to be savoy enough to do that and try that, and if that does not work you may need a new power supply. You can check it but probally will be bad I have the same desktop and thats been a problem with these 5150 along with the mother board going out after the warranty expires. I sure Hope this helps you out,, Happy Holidays to you and yours. Hey If you need me to look anything else up let me know. Thanks again bear001
SOURCE: dell dimension 5150 won't start
See solution in http://www.fixya.com/support/t1372311-start_up_fault
SOURCE: computer will not boot
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=6EB139500365CBA6E040AE0AB5E109D6&treeid=286725
See that link for the beginning of the Dell troubleshooting wizard for diag lights 3 & 4, it is in fact a memory subsystem error. Usually meaning the stick of memory in the first slot is bad. The wizard will walk you through this, but try removing the first stick and using the second stick in the first bay and see if it will boot. Unfortunately no recalls on RAM for this model but the good news is that your memory is cheap and if your not under your service contract you can buy a set on newegg or a similar site for about 50 bucks.
SOURCE: only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Suggested Resolution
Solid green
Power is on, and the computer is
operating normally. On the desktop computer, a solid green light
indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
