RX-797 no sound output except when "Pure DIrect" button pushed
Here are some things to check:
Is the loudness control turned off or set to a very low level? If the PURE DIRECT button is turned on with the LOUDNESS control level at 0, you won't hear anything.
Have you removed the jumpers from the PRE Out/MAIN IN jacks? If so, the unit will only perform as a power amplifier.
Is the CD DIRECT AMP turned on?
If so, the unit will only make sound if the PURE DIRECT button is on.
Check the CD DIRECT AMP and the PURE DIRECT buttons are both turned off. This should produce sounds. If ti doesn't, check that the A and B buttons are on for their speakers. Both can be on.
