Heating & Cooling Logo
A
Anonymous Posted on Jun 11, 2014
How do I Remove cover on soleusair? - Fujitsu 18R1 Air Conditioner
I get an E4 error message on my SoleusAir PE1-09R-30 system
Have you tried to hard reset your AC by flipping the breaker? If you need more questions for your AC Repair needs, check us out online.
What is wrong when reset switch on plug keeps tripping on a soleusair ph5-13r-35d?
There is a short either in the line or the unit, reset and check for short between the two lines with ohms tester.
I’m happy to help further over the phone at https://www.6ya.com/expert/fred_9ea6f00d14da8ce5
2answers
Where is the fuse located on my soleus air conditioner lx-140 house unit. I want to replace it.
PDF]download manual - SoleusAir
www.soleusair.com/Manuals/2013%20Manuals/.../PH4-13R-01_Manual...
Thank you for choosing a Soleus Air Portable Air Conditioner with Heat Pump ... owner's manual will provide you with valuable information necessary for the
Have error Code E4. What do I do
this site may or may not help Tim:
http://www.soleusair.com/soleusair/trouble_portables.html
Soleus CFM40E
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
[email protected]
Top Fujitsu Heating & Cooling Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
