SOURCE: can't find my wireless network with my desktop
open internet explorer or firefox and in the address bar enter
192.168.1.1 and press enter
then it will prompt you for a username and password
ignore the username field and enter the password as admin and click on ok or press enter.
This should take you to the configuration page.
go to the linksys site for your router here
Click on user guide - you will need adobe reader to open this so if you dont have adobe reader then you will need to install it.
Once installed you should be able to open the user guide which will walk you through how to configure the router with regards to wireless etc.
SOURCE: linksys wrt 160n v2 wireless router disconnecting
Wrt160N router has some issues with the firmware .
Try to upgrade the Firmware of the router.
For that you will need to download the firmware form the web site.
open the set up page of the router.
under administration TAB you will find Firmware upgrade SUB TAB.
go to that tab . select the firmware file that you have downloaded.
and upgrade the firmware.
Click Here for more info about how to open the set up page of the router and other networking info
SOURCE: I have just bought a Linksys WRT 160N but when I try to instal it
OK
CAN YOU MAKE A RESET FOR THE NEW ROUTER ,TO PUT IT IN DEFAULT SETTING ?
SOURCE: ps 3 linksys 160n problem
Hi Friend,
In order to use PS3 we need to open few ports. Kindly follow the steps:
1.Open the internet explorer and type 192.168.1.1 and hit enter.
2. If you have not changed the default password of the router then kindly leave blank the username box and in the password box type admin and hot enter.
3.In the setup page click Application and Gaming
4. Under that click Port Range Forwarding.
Below are the port numbers which we need to open for PS3
TCP:
80
443
5223
UDP:
3478
3479
3658
Now please type these port number in start and end port. Please make sure start and end port has to be the same.
First enter the TCP ports in first three boxes and then UDP ports in next three boxes.
Save the settings and turn off the router for 10 seconds and restart again.
Enjoy.
Regards
Chiranjeet
SOURCE: I have a full signal in my ATT modem but the
You have WRT160N router. This router has issues with the Firmware. Firmware is the software of the router.
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
