Zebra TLP 2824 Printer Logo
A
Anonymous Posted on Jun 10, 2014
HOW TO CHANGE RIBBON ON TLP 2824 - Zebra TLP 2824 Printer
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Nov 09, 2007
SOURCE: Printer will not print
zebra have only just started to support vista, you need to download the latest version of zebra designer from zebra(free). drivers are included
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Sep 17, 2008
SOURCE: Zebra TLP 2824 Printer problem
How are you loading the labels in the printer?
Make sure they are secured underneath the black side guides?
Anonymous
  • Posted on Jun 09, 2009
SOURCE: ZEBRA TLP 2824 LABEL MAKER PROBLEMS
I've had this problem. I changed the margins and it solved it.
Jim H
  • 62 Answers
  • Posted on Nov 20, 2009
SOURCE: Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Apr 11, 2010
SOURCE: how do I change ink ribbon in TLP 2844? Please
That's a good qustion. What does the "T" in TLP stand for? I don't know where you live, but you might try this link http://www.peaktech.com/supplies/?gclid=CKnN3rTh_qACFUFM5QodET8qxw
You're going to need it for label stock. You might need it for a new print head if you have destroyed yours.
ANSWER: There is no ink, it's THERMAL
Out of ribbon
Then change the ribbon, my friend. You need to be more specific
I have wristbands that are continuous without sensing mark. can i set where the print area beings and ends for each band in continous mode on zebra tlp 2824 printer
Go to "Printer Settings" and set the size/width/start/end. There will be numbers in MM that you can set everything up by.
How to install zebra tlp 2824-z
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/drivers/results.html?productType=7
finish the instalation, reset the computer. Turn on again, check on printers and fax, if the icon is there, right-click and go to properties, print test label.
2helpful
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while...
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
1helpful
Zebra TLP 2824 Print Orientation
check on the driver, unther the advance tab, if some seting is tick.
if cant check the problem, install the driver again.
2answers
2answers
this happens with me also. it is random. could happen once a day or several for no apparent reason. I am printing thru Terminal Services though.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
