Question about Onkyo TX-8211 Receiver
Onkyo tx-8211 standby - Onkyo TX-8211 Receiver
6ya staff
SOURCE:
simplemitch
Mitch
  • 752 Answers
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Posted on Sep 15, 2007
Anonymous
SOURCE: Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Posted on May 12, 2008
Anonymous
  • 142 Answers
SOURCE: standby button stuck
Hello. Check all of the buttons on your unit to make sure that they are not stuck...you can feel the click they make as you push it then they pop back out as your finger pulls off. Any stuck button will lock up your microprocessor and keep the unit from turning on. All other problems will require a consumer electronics technician to trouble-shoot the turn on circuit. If you know how to use a meter and know how to solder\unsolder and require further assistance you can contact me. Good luck.
barneyluc
Posted on Oct 19, 2008
ABRsvcs
  • 4234 Answers
SOURCE: receiver does not power on. standby not on either
The standby light should be on. If it is not, then check the main fuse. WIth the unit unplugged, remmove hte top cover and check the fuse by the line cord. If that is ok, then you will need to check the primary winding on the standby transformer. That transformer has a thermal fuse internally located and that sometimes gets blown due to a power surge. If you do not have the equipment to test this, get a detailed estimate from a local servicer. The standby transformer usually costs arounf $25 or so.
Dan
Posted on Apr 26, 2009
Anonymous
SOURCE: onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Posted on Jan 26, 2010
What is the signal to noise ratio of the onkyo tx-8211 at its phono input
Why not enter the info into a search engine? Or try their site . . .
SEARCH ENGINES ARE YOU FRIEND!!!
Sep 11, 2015 | Onkyo Audio Players & Recorders
Onkyo tx 8211 receiver shut off problems
Check all of your speaker wires and speaker turminals. I bet there is a short.
Apr 26, 2012 | Onkyo TX-8211 Receiver
TX-8211 FM Stereo/AM Receiver All has been fine
make sure that somehow the wires didn't get loose from the speakers in the back. Protect means that it's overloaded. Did you change the plus wires with minus wires maybe. Check to make sure all the wires are good.
Mar 19, 2011 | Onkyo TX-8211 Receiver
I have a TX-8211 but I am out of town looking at Internet Radio tuners. Can you tell me what type of inputs are on the Onkyo? I know it has the black/red spring loaded wire inputs but are there other...
Your tuner will be the limiting factor regarding sound. The Onkyo accepts any stereo analog input via RCA connectors, period.
Those "black/red spring loaded wire inputs" are speaker outputs and if you hook one of those to an innocent audio device's Line In connections you might kiss it all goodbye.
Read the manual...
http://www.retrevo.com/support/Onkyo-TX-8211-Receivers-manual/id/365ci165/t/2/
Feb 01, 2011 | Onkyo TX-8211 Receiver
Onkyo tx-sr507. was listening to music and suddenly cut out. Will not restart despite disconnecting all speakers etc. standby light flashing
standby light flashing means that it has had a thermal meltdown given that the onkyo can not be that old i would contact onkyo support because our model should be under factory warranty
May 24, 2010 | Onkyo Tx-sr507 A/V Receiver
Onkyo TX 8211 protection mode is activated and i want to know how to deactivate it????
Eliminate the short or overheating problem it thinks exists. Disconnect all speakers first to see if one of them is the culprit. If it's internal, take it to a shop.
Jan 19, 2010 | Onkyo TX-8211 Receiver
Onkyo tx-8211 protect
It's unlikely you can. Most hifi shops can though.
If you're still reading, open it up, and look for a switch of some kind. It may not even exist, but I'd say it's the best thing to look for when doing something considered mediocre at hifi shops (if it was difficult and interesting, they wouldn't find it so boring). Maybe it's a button. It will probably be labelled protection or reset or something similar.
So, look for a switch, or something similar. I have no idea where it would be because I've never dismantled such a thing. The other option (if you haven't done so already) is unplug it from the power and leave it for a while (overnight may be the best bet). This may fix it for you, and it's easier than undoing all those screws.
Jan 13, 2010 | Onkyo TX-8211 Receiver
Onkyo Receiver tx-8211 won't come out of standby.
try unplugging the unit for couple of minutes the plug it back in
Dec 25, 2009 | Audio Players & Recorders
"standby" on Onkyo TX-910
That sounds like an internal problem inside the unit
Jul 18, 2017 | Onkyo TX-910 Receiver
Onkyo TX-8211 Receiver Logo
193 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
