I have had my Kindle attached to the plug-in charger (which was plugged in) all day, and it is telling me that the battery is too low. I have also had it hooked up via the USB to the computer for the last 20 minutes and it is still telling me to charge it for at least 15 minutes. What the heck is going on?
SOURCE: My kindle will not charge. I plug it in and there
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
SOURCE: The kindle screen is frozen on the sleep mode, the
Try a different charger. If that fails too, you have a logic board issue. Amazon should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: I have a kindle and connect to usb on a Windows 7
I guess you're trying to eject the Kindle from the task bar "(safely remove hardware". Try going into Start/Computer/right click on Kindle/ select eject. This worked for me when I had the same problem.
SOURCE: how long should I leave my kindle plugged into charger
From a guess,about an hour.But keep checking on it.
SOURCE: `kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
