SOURCE: Copies are half printed and half almost not printed (very lite)
If the copy count is around 150,000 or higher and you haven't replaced the developer as well, it should be replaced. That symptom can cause light copies if it hasn't been replaced every 150,000 cycles.
SOURCE: ricoh 2022sp internal tray 1
Where the paper comes out there is a little black thing that is supposed to stick out. Somebody has pushed it in.
SOURCE: I have a problem with my Ricoh Aficio 2022sp. It
Something around the drum need to be replaced. There are two ways to be done. Because Ricoh do not offer a replacement by parts around the drum unit for this machine by Ricoh you can only replace the hole drum unit. But as you say you have a problem with the drum cleaning blade, or in worse case the drum and the cleaning blade for the drum need to be replaced. So Katun offers a replacement by parts and by Katun is more cheap to be replaced. This is what is the problem, so on your hand is what are you gonna decide.
SOURCE: HOW TO REBOOT RICOH AFICIO 1515MF??
need to enter service programs print out 5990-2
then exe 5801 memory all clear
put all the settings back to where the were set
the printout will show you default and current settings
