Even after turning the PC off, the drive is running. I have to manually power off with the switch. I'm running WIN XP. I know I should move to a newer OS, but this is an older PC and my funds are limited.
SOURCE: Trying to get data off an IDE drive from a dead system
this MS link will help you configure it so you can read it
http://support.microsoft.com/kb/309000
SOURCE: Simple Tech collaspe
my english is very bad but I try to explain you.
This is a very common problem with external disk (and it happen very often with simpletech).
2 possible solutions
1- buy another case sata and change the disk to the new case.
2 - Open simpletech's case, (its easy) In some cases if you open de case and take out the board inside, you would see humidity (not in the board of the disk) If you let this board several days out of the case, after that clean it with isopropyl alcohol and then wait one day more and assembly all again, in most of the case and the disk will we run again.
I hope this solve your problem,
I repaired a lot of simpletech in that way.
SOURCE: My Verbatim 320GB portable drive will not work with my iBook G4
Called Verbatim support and they said it is a power issue. They will send you a USB Y cable to get power from both USB ports. Hope it works.
SOURCE: I have an older Maxtor hard drive Model 90645D3.
Hello
At the back of the drive, you should be able to see the jumper setting. There must be a small jumper in as well. Have a look at the pic, and just set it to slave and you should be set.
Kind regards
Andrea
Testimonial: "TY very much! I'll give it a try. It had a shunt on the furthest left 2 pins originally. I wonder about that--it's not shown in pic. I'"
SOURCE: have new drive Hitachi SimpleDrive Mini 250GB USB
Most USB hard drives require an external (or secondary) power cable to power the devices when connected to laptop or netbook computers. In some cases, even older desktop computer models will require a similar cable.
This is due to the specifications for the USB standard as it dictates the amount of voltage that a USB port can deliver. Some USB ports are considered "powered" and are sometimes identified by the USB logo and a small "+" sign to indicate the added voltage.
Note: Not all manufacturers use this logo, so if your computer doesn't have this variation of the logo, it doesn't necessarily mean the USB port is not powered.
This added voltage supplies additional current to power smaller devices, such as portable (or 2.5") USB hard drives. However, in the even that the USB port is not powered, then only the minimum amount of current is supplied. This should be enough to slightly power the drive, but not sustain it, thus causing the clicking noise and there isn't enough current running through to move the arm that reads the data on the hard drive.
Chances are that the USB ports on your Asus Eee are not powered and won't allow your hard drive to run until either a secondary cable is purchased or if you use a powered USB hub instead.
The secondary cable looks a lot like a Y-USB cable with one end that connects to your hard drive and the other end consisting of 2 USB plugs that both connect to existing USB ports on your netbook. Between the 2 USB ports, they can draw enough current to power the hard drive - the downside being that if you only have 1 USB port you cannot utilize the cable or if you have 2, they will both be occupying the ports while the hard drive is in use. These cables can cost about $1-7 depending on brand and can be found online in retailers such as eBay & CompUSA.
The USB powered Hub is a more expensive solution, ranging at about $10-25, but is the higher recommended of the 2 solutions since it will provide its own power supply to the tiny device, will use on 1 of your USB ports and since it's a hub, they usually have anywhere from 3-5 additional USB ports (all powered) for you to use, if needed. Some even include built-in memory card readers and they do not require any additional drivers or software to install and can work on any desktop/laptop/netbook.
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need data and power to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power connection or faulty fan lead can cause you problems
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram modules make sure they are securely seated
on some motherboards cmos batteries are soldered in
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
hope this helps
