I can help you with your Sharper Image remote control.
There are
two Sharper Image Remote Controls: a Sharper Image Jumbo
Touch Remote Manual, and a Sharper Image Jumbo
Remote Manual. Click the above links to review which remote you have, and download the appropriate manual.
The programming instructions will be different depending on which Sharper Image Jumbo remote you have.
I hope that helps.
Send me your email address and I will send it to you.
[email protected]
AL
I have it in a pdf if you would like it just email me at [email protected].
SOURCE: NEED MANUAL FOR SHARPER IMAGE JUMBO UNIVERSAL REMOTE 1613086
The manufacturer of that remote is Emerson. Here is the manual.
http://mscustomercare.com/forms/JumboRemoteEM_InstructionManual.pdf
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
click the link http://mscustomercare.com/ scroll to the bottom of the page and download instructions for jumbo remote.
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
SOURCE: The sharper image jumbo universal remote jvc tv
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
