SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
SOURCE: what is the correct oil to gas ratio for an Echo
Fuel/oil mix ratio should be 32to1 or 32 ounces gasoline to 1 ounce oil.
Thanks!!
Testimonial: "Very prompt answer."
SOURCE: echo es-2100 is running real dogie. Won't run @
sounds like the exhaust is indeed stopped up echo part number 14586240630 is the exhaust screen, they can be easilly cleaned with a torch to burn off the carbon build up.......hope this helps
