Question about KitchenAid KHMS2050SSS Microwave Oven
Problem - Ghost in my microwave keypad? KHMS2056SBL scrolling screen at will
At any moment of the day the microwave will randomly scroll through screens; selecting a choice on the screen and scrolling on to another screen. As far as I know, it has not turned itself on, YET. We unplug it when we'll be gone overnight. I've had a tech out to look at it, but he states there is nothing they can do unless it happens while he is here investigating issue; don't know how that will help him, ugh! I would appreciate your help. Thank you.
    New Friend:
I am glad to hear someone else is having the same issue we are. We've been dealing with this for about a year. We've called Kitchenaid numerous times and they say they seem shocked as if no one else has this issue. Thanks to all who suggested how to fix this and we'll give it a try.
Posted on Aug 10, 2014
  • Louis Davis
    Louis Davis Jan 30, 2019
    My KitchenAid khms2050sss-2 just started with the phantom control panel activity. At random it will punch a series of buttons, but it hasn't start itself - so far.
    I'll contact KitchenAid to complain, but it's 9 years old so I'm not hopeful.
    I love the unit but reluctant to put any money into it, as it's so old.
    I tried disconnecting for 1 minute as suggested below, but that didn't help. Neither did the 5 minute disconnect, so I'm calling KitchenAid tomorrow.
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
I'd check to make sure it is plugged into a grounded outlet that is actually grounded. If it is, it's likely a failure of the control panel circuit board. I agree with the tech, I'd have to actually see the malfunction before confirming any diagnosis.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on Jun 10, 2014
3 Suggested Answers
Anonymous
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave makes beeping noises and comes off and on by itself
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, you probably have a failed membrane keypad.
Is it possible that some spray cleaner or steam accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Also be sure your filters are cleaned, or in the case of charcoal types, replaced.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
But please note that for some models, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself
job.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 28, 2010
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: I have a F6 error
F6 on these models means that the cook relay on the control circuit board is shorted, and it is cooking anytime the door is closed.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
If you prefer, you can buy a new circuit board (part number 8169733 for $150.27) from the Pros
here.
They're our favorite supplier.
Posted on Sep 08, 2010
I have a Panasonic Model NN-P295SFR microwave. it just stopped the other day.
Have you had a power surge or outage? sounds like the main circuit board lost its programming.
Sep 22, 2017 | Panasonic Microwave Ovens
If left plugged in, microwave fills timer screen with "7's" then scrolls "push start". Circuit board? Fix?
I would say that the number 7 button is either broken or stuck in. If still under warranty, take it back. Otherwise, contact the vendor of the microwave and ask them how much it would cost to fix it. Generally, it's cheaper to buy a new microwave than replace the circuit board, unless you can find second hand parts on eBay or a similar site.
Jul 14, 2015 | Microwave Ovens
Kenmore microwave oven has S-E error how do I clear it or troubleshoot?
it is experiencing a defect in the control panel.
gotta call sears on that one, could be as "simple" as replacing the control panel or up to the wiring TO the control panel
Sep 19, 2014 | Microwave Ovens
Ge jnm1541sn1ss
please do these test and fix it. God bless you
  1. Controller is confused A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switches This can result in the controller thinking the door is open and ignoring you.
  3. Cleaning Cleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Dec 12, 2013 | Microwave Ovens
Setting level power of microwafe samsung
You can either choose to select the SET levels for the heat which can be a direct button or you can select the power button and scroll up or down the settings. Also the weight of the food must be chosen to be effective for the heat.
Click on Microwave
Jan 31, 2013 | Microwave Ovens
Power went out. Microwave just scrolls press clock!!!!!!!!!
Did you figure this out? I am having the same problem. I see PRESS CLOCK on the control display. But none of the keys on the touch pad work. GE sucks bigtime !!
Jan 17, 2010 | GE Spacemaker JVM1540 Microwave Oven
Cana I download an instruction manual for the MCD1311ST?
Go to this link to get your user manual:
http://www.devicemanuals.com/guide/Microwave%20Oven/Magic%20Chef/Magic-Chef-Microwave-Oven-CT-MCD1311ST-Instruction-==TVRJek16UTU=.html
When you get there, scroll down and enter the validation code.
Then on the next page, scroll down and click on Download Now.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 17, 2009 | Magic Chef MCD1311ST Microwave Oven
The microwave suddenly beeped several times, the scroll directed to push clock button, but no button would respond and then F3 appeared on screen but no explanation. We unplugged microwave a couple of...
The code f3 is a short in the key pad for more than 60 seconds
go to GE .com and enter your model # and you can get a price to do it your self
Good luck
TEETERMAN
Aug 17, 2008 | GE Microwave Ovens
KitchenAid KHMS2050SSS Microwave Oven Logo
2,294 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
