With a new bag in the compartment, Turn the dial on the top of the vacuum all the way in the opposite direction and try it again. If it still persists, the control valve that you're turning most likely needs cleaned or replaced. I can help with that.
Hope it helps. [email protected]
SOURCE: Lux5000 will run until hose is attached, then
Experienced the same problem, just fixed it! Lift up the control dial on top of canister. You will see two small clear hoses inside. Detach the hose going to the "bag full" sensor light. It'll fix the problem!
SOURCE: Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
