How do i aktivate my dongle? - i have got a new pc
SOURCE: Husqvarna Viking Designer 1 Beeper
when i,m doing a machine embrody the thread will fray in the needle and spoil the whole design, i,m afaird to do anything on a piece to keep. what is the best thread to use
SOURCE: dongle
I believe that the information that you have been given is correct. The VIP dongle is no longer available.
As for the second part of the question, do you have a damaged dongle or has it been lost completely? If it has been lost, there is no way to replace it without buying a new software package.
SOURCE: Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
SOURCE: Need Viking Husqvarna Designer 1 ESS Owner's Manual
Try ebay or contact your local authorized Husqvarna Viking dealer. You can find a dealer closest to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us/
SOURCE: Dongle for Designer 1 not recognized in XP or Vista
Drivers can be found on Husqvarna Viking website (search for VIP software) under "other links". Here's the direct link - http://www.husqvarnaviking.com/us/8588_4197.htm
I don't think 3D/VIP is compatible with Vista but should be compatible with XP. Download and install latest driver per Husqvarna Viking website.
Good luck !!
