Modem green light still on ,but the 5 line symbol for internet access on screen gets a x
Most likely bad connections.
Tighten all cable connections.
Testimonial: "from the wall to the modem got be good ,as said green light on modem never turns off ,from modem to my po the connection was set up wireless ""
Try bringing it closer to the modem. It that does not work, contact your service provider.
yes already all done that ;service provider tried to put the fault on my browser ,and we went thru a whole cleaning process ,and oops the problem still here
See if their is any support here that applies.
the link you provided leads me nowhere ;
Add a CommentOops. The page you were looking for doesn't exist. You may have mistyped the address or the page may have moved. Take me back to the home page
Woops , sorry. www.westell.com/contact-us
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
