Question about Sharp AR-M160 Black and White Copier
Simulation sharp ar m165 h4 - Sharp AR-M160 Black and White Copier
Anonymous
SOURCE:
Anonymous
  • 146 Answers
SOURCE: Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Posted on Jun 06, 2008
Anonymous
  • 62 Answers
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Posted on Jul 30, 2008
Anonymous
  • 37 Answers
SOURCE: SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Posted on Mar 01, 2009
tehnik_bdg
Budi Raharjo
  • 91 Answers
SOURCE: Sharp AR-M207 Error Message
H4-00 means heat roller low temperature detection. It usuallly caused by 3 things :
1. The machine hang : You simply reset the error code by pressing : # * C * then input 14 then start.
2. If the error still displayed, open the side cover, feel the fusing unit ( don't touch, it is hot ), if the
fusing unit feels cold then the problem is the heater lamp ( inside the upper heater roller,
connected with anti heat cable and big connector ), you should replace it.
3. If the fusing unit feels warm or hot then the problem is the thermistor ( connected with small cable
and connector ), replace it.
Posted on Mar 04, 2009
Warrick Lee
  • 32 Answers
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Posted on Mar 25, 2009
Sharp AR-M165 simulation code H4-00
try this...
Steps
We'll need to enter the simulation mode by pressing the # * C * 14 (HARSH - STAR - C - STAR - 14) and then hit the copy button twice. The machine will restart and the error code will stop showing.
You have successfully rebooted your Machine...
Note: You will need to have a fast finger for it to enter the simulation mode.
Oct 31, 2017 | Sharp Office Equipment & Supplies
Sharp m165 error h4-00 give solution
Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
harness.
input circuit.
Check for heater lamp
disconnection or thermostat
disconnection.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
May 12, 2014 | Sharp AR-BC260 Color Copier
What is sim 14?
Simulation 14 is Trouble Cancel (except for U2)
http://einfo.thecircledelivers.com:8081/Techs%20Folder/Manuals/Sharp_Digital_Copier_AR-M207,AR-M165,AR-M162_Parts_&_Service.pdf
page 39 lists all of the simulations and how to canceling out of simulation mode.
Feb 21, 2014 | Sharp AR-M207 All-In-One Laser Printer
Sharp ar-310nt getting an error code h4-01
Fusing unit error.try to cancell by using program/simulation.cancell by 14
Nov 19, 2013 | Sharp Office Equipment & Supplies
Sharp m165 showing error H4-00
H4-00 relates to the fusing unit not reaching the desired temperature. This could be due to a heat lamp or thermistor failure. I would recommend calling your local service engineer. hope this helps.
Apr 22, 2013 | Sharp AR-BC260 Color Copier
AR-M150 shows h4 but it does'nt have interrupt key
There is need to solve the low current problem by simply rectifying it frfom the power supply.
enter simulation (use SIM14) 'C' 'auto' 'C' 14 copy key
Jul 16, 2011 | Sharp AR-M160 Black and White Copier
My sharp problem is f2 Another problem is H4
F2 promlesm is you have to change the toner,maybe you had put a wrong toner.
H4 is a fusing problem and you have to enter simulation mode and reset it with 16 start.
Aug 12, 2010 | Sharp AR-5316 Advanced Digital Imager...
Code: H4-00, H4-0Q
H4-0 The fusing unit doesn't heat up.
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Jan 25, 2009 | Sharp AR-M350N Copier
Sharp AR-M237 DISPLAY READS CALL FOR SERVICE CODE H4-20
ussually h4 appears when the heater lamp is busted. but to really be sure just simulate C # C interupt (enter )04 then press start. if problem persist. chect the lamp and if find busted repalced it.
Dec 16, 2008 | Sharp AR-M237 Digital Copier
Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Aug 18, 2008 | Sharp AR-M207 All-In-One Laser Printer
Sharp AR-M160 Black and White Copier Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
