Cars & Trucks Logo
Brooks page Posted on Jun 09, 2014
1996 ford f150 reg can short bed 351 Windsor e4od trans 4x4 I took a turn coming home from work and while completing my turn in lost power steering and then a few seconds later the engine shut it's self off I have battery power fuel pump turns on but when I try to start the truck it doesn't turn over I can't find a simple source so I'm asking for suggestions on what it could be
spock spock
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Jun 09, 2014
spock spock
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
Helped
77504
Points
23
On a 92 they are not too seious with the electronics yet. is it manual clutch swich or automatic has to be in park to restart.
5 Related Answers
Anonymous
  • 170 Answers
  • Posted on Aug 21, 2009
SOURCE: 1990 F150 Fuel pump just replaced but wont turn on
Replace the fuel pump relay. And if your truck has dual tanks there's three fuel pumps, one in each tank and another secondary fuel pump.
Rich Notarianni
  • 161 Answers
  • Posted on Dec 18, 2010
SOURCE: where is the fuel pump
Probably in the gas tank.
Anonymous
  • Posted on Jan 03, 2011
SOURCE: my 2005 Ford F-150 4x4
Was it the fuel pump? If not I would consider the charging system ie) battery, alternator or both.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 09, 2012
SOURCE: 92 Ford f150 4x4 automatic trans mission changed
You may have knocked a piece of dirt loose or the fluid level is to high or to low, add a can of LUCAS transmission conditioner and see if that clears up the problem.
Anonymous
  • 689 Answers
  • Posted on Nov 10, 2012
SOURCE: Were is a vaccum modulator located on a 92 Ford
It has to do with your brrake system booster drum ,
2answers
Will a f350 with a 460 ci transmission fit in a 95 f150 with a 351ci
I guess the short answer is I doubt it.
The 460 engine should be a big block and the 351 is probably a large 302. I would expect the bolt pattern for the bell housing to be different along with the mounting and the tail shaft.
The 460 should have a bigger drive shaft than the 351.
If you can get the model of the 460 trans a salvage yard should be able to tell you if they will interchange.
92 Ford f150 4x4 automatic trans mission changed fuel filter and changed transmission filter wont shift any more once u get pass 25 to 30 MPH it has the 351 Windsor motor and aod type transmission what...
2helpful
What automatic transmission was used in the 1992 Ford F-250 Diesel
A.T., 4x4, AOD (5.0L)
EAC}G}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 11-1/4" ext hsg
EA}}}400" type="radio" name="userInterchange" />M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
M.T., 5 spd, ZF, 4x4, 8-460 (7.5L)
M.T., 5 spd, ZF, 4x4, 8-445 (7.3L, diesel)
EAA}N}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 10-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 12" ext, elec speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, elec speedo
F>}A}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-460 (7.5L), (elec speedo), (tag F2TP-YA)
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), elec speedo
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID F4TA-BA & BB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID F4TA-BA & BB
>C}}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, elec speedo
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 2.73 ratio
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.08 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.55 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 4.10 ratio
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2TP-BA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2UP-DA & DC
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-302 (5.0L), (elec speedo), (ID F2TP-DA)
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2TP-FA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2UP-EA, EB & EC
?}}}400" type="radio" name="userInterchange" />A.T., 4x4, E4OD, 8-351 (5.8L), (elec speedo), (ID F2TP-HA)
}}}400" type="radio" name="userInterchange" />A.T., 4x2, C6, 8-460 (7.5L), (elec speedo), ID F2FP-CA & DA
A.T., 4x4, E4OD, 8-460 (7.5L)
E}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; w/o ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), w/o ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), ID F2FP-BA
A.T., 4x4, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, E4OD, 8-460 (7.5L)
A.T., 4x2, C6, 8-445 (7.3L diesel)
EF}D}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-351 (5.8L)
Good luck
2answers
1996 F250 Brakes
Seems regular maintenance would be required for your cable issues, and lubing them or limiting your salt water/road salt exposure and/or any underwater/extended wet exposure.
Other than replacing the mechanical section INSIDE the cab, there's nothing else that can be replaced. Besides buying a new truck. ;) Cheers.
2answers
Will a 2001 E4OD transmission fit my 96 F150
I would say that physically the transmission may fit due to the engine sizes being the same, but the 96 F150 is a E4OD transmission and the 01 is a 4R70W transmission, they do not work the same electrically.
2answers
Transmission swapp
The difference that you're going to find is that the bellhousings are different. The trans out of the 5.0L will not bolt to the back of the 7.5L engine that you have.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
