Festina Chronograph 16162/1 watch Logo
A
Anonymous Posted on Jun 08, 2014
How to set my alarm on festina watch
Can get the alarm to operate on my festina watch
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jul 05, 2009
SOURCE: setting the time, day, date, ona Festina 16059/4
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Anonymous
  • 2501 Answers
  • Posted on Mar 12, 2010
SOURCE: I need a manual for a Festina, Chrono Bike, watch
Festina do not have much of a web site at present but if you go to "www.festinausa.com/", you will see a customer service address who may be able to help you.
Anonymous
  • Posted on Mar 19, 2010
SOURCE: I don't have the user's guide of festina f16235
I have the same watch.
Here:
http://www.citizen.co.jp/miyota_mvt/download/pdf/manu_6P27-77_multi.pdf
is a manual for it's movement, Citizen Miyota 6P27.
Anonymous
  • 2501 Answers
  • Posted on Mar 06, 2011
SOURCE: I need a Festina F16275
Go to http://www.festina.com/ , click on "downloads" and put your watch model in the search box and click on
"search".
You will then receive a copy of the manual you require.
Testimonial: "Thanks. Wasn't able to find this info without your help."
Anonymous
  • Posted on Mar 28, 2011
SOURCE: Festina F16289/1 Alarm problem
humidity inside the CLOCK
I just got this watch but the alarm function doesn't seem to work after following the manual's instruction and trying it several times? Any suggestions on how to fix it?
If you can't set the alarm function follwing the instructions of a new watch, might mean that this watch is defective and should be covered by warranty. If you mess with it, you'll lose the right to claim warranty service, so should return it to the shop where you bought it or take it to authorized servce according to warranty terms.
Hi , where can I get the instruction manual for my festina multi function depose 6623 watch
"search".
1helpful
2answers
How do I set a Festina 6580 Richard Virenque edition wristwatch
Any1 no the price of the festina chronograph Richard virenque watch
Hello any chace i could get help with getting a user manual for the festina 6561 chrograph alarm
Go to http://www.festina.com/ and click on "downloads".
You will then see a search box on the left. Follow instructions to get your user manual.
Mar 12, 2011 • Watches
Festina date set
if you go to Festina.com and select downloads and then enter your Festina watch number you can download the entire manual.
Good luck
8helpful
Check out my tips here and find the instructions manual for your watch.
4helpful
How do I set the time and date?
Twist the crown until you can pull it back one notch. This will set the alarm by twisting in one direction. If you twist it in the other direction, you will set the date. Pull back one more notch and this will set the time. One you've done this, push and tighten the crown back in and press the bottom right hand button. The second hand should begin moving.
7helpful
Festina chrono bike 16162
Pull the crown out to the first click, then you can turn one direction to set the alarm, and the other direction to set the date.
Top Festina Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Festina Watch Expert? Answer questions, earn points and help others
