SOURCE: how to replace accessories from a husqvarna power motor
Straight from Husky, the pole saw runs about $200...or if you have the straight shaft, you can get just the head for $185:
http://www.husqvarna.com/us/homeowner/products/trimmers/popular-accessories/
SOURCE: can i get a owners manual for a 128cd trimmer
You can get the manual on the link below. If that is not the right trimmer please give make also.
http://www.southernstates.com/docs/manuals/10301494_om.pdf
Good Luck and please rate 4 thumbs up for the free answer
SOURCE: how do i repair a choke lever in a weedeater
Upon inspection of this model machine, it appears that the choke lever shaft is pressed into place when the carb is manufactured. Removal may be possible, but probably more damage will occur. I have this same model machine with a Zama carb having flooding issues after soaking in a bath-type solvent overnight. This is NOT recommmended.
Here is a parts breakdown for your machine:
http://www.ereplacementparts.com/weed-eater-te475y-gas-trimmer-parts-c-17589_17626_18141.html
Unfortunately, there is no avaiilable release date for the part you need in question....On the page I made available it is part # A800 or A801...depending whether you have the Walbro or Zama carb. Mine has the Zama.
SOURCE: Husqvarna 128CD trimmeer Installing the piston
You need a ring compressor. They have plastic ones for cheap. Ask your dealer
SOURCE: Suddenly, my Husq string trimmer shuts down when
326 sl it runs for 5 mins and then dies out it acts like it is overheating it seem to be hot
