You will have to take off the back of the TV set to reach the board. The board looks like the one at; http://www.shopjimmy.com/lg-6632l-0604a-backlight-inverter.htm
Try the video also.
SOURCE: Inverter opertion
Hello davidweldon,
If the inverter board is bad, I would suggest that you replace the whole board unless you have a SMD (Surface Mounted Device) rework station, and a background in electronics. I have worked on TVs where people have tried to remove SMDs and it never is an easy thing to do, so I would again suggest that you replace the whole board, because all of the components are SMDs.
Now as to your question, I have seen on these sets the majority of the time it is a driver transistor that goes bad.
I hope this helps,
Thank you,
Shuttle83
www.electron-age-technologies-llc.com
SOURCE: sanyo dp42841 is making a crackling noise
determine first if with sound off you have the problem---if not it is audio related and if with sound off it is still there it is inside the set....
SOURCE: My tv went completely out. Is there a reset button
Try unplugging it. That is usually the reset.
what video, I already took the back off and already replaced t-con board
