Kodak PIXPRO AZ362 Bridge Digital Camera - CMOS 16MP 36X Optical Zoom FHD1080p -Black Logo
A
Anonymous Posted on Jun 08, 2014
How do I turn on flash
How to turn on flash
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Kodak Expert 527 Answers
  • Posted on Jan 06, 2015
 Paul Green
Kodak Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232752
Points
686
On the top side of the camera is a button that says Open and this pops up the flash with should then activate. Have a look in the camera menu to ensure flash is selected as active. Sometime your camera flash will only work when the camera decides there is a need for extra light.
  • Arthur Cowgill Jun 03, 2015
    teddyboy is right, auto flash opens up when it is needed. but if there is a flash button on the camera then you can press this to uses it, don't for get to push it back in when your finished.
2001 tp cruiser turn signals wont flash
check the flasher relays in the fuse box. these are what causes the lights to flash.
1helpful
How to disarm security on a dyna wide glide
if I remember right , this will work for your bike, Step 1: Turn ign key on-off-on-off-on
Step 2: Press left turn signal 2 times and release
confirmation: 2 or 3 flashes on turn signals (depending on
configuration) 2 for USA, 3 for everything else
Step 3: Press and hold key fob button until confirmation recieved
Confirmation: 1 flash on turn signals
Step 4: Repeat step 3
Confirmation: 2 flashes on turn sigals
Step 5: Press left turn signal 1 time and release
Confirmation: Turn signals flash to indicate option selected:
1 flash - Auto arming disabled
2 flashes - auto arming enabled
Step 6: Repeat step 5 to switch between auto / auto off
Step 7: Turn IGN switch off
1helpful
How do you turn the flash off?
Press the flash button (right on the multiselector, marked with a lightning bolt) repeatedly to cycle through the various flash modes. To turn off the flash, select the lightning bolt in a circle with a slash through it. Don't forget to turn it back on later if you want it to flash.
2answers
2000 Hyundai tiburon all lights flash when turn
The new marker turn signal lights came with 1 element bulbs and the tiburon takes dual element bulbs . Problem fixed.Cant believe they came that way from the dealer.
2helpful
How can I turn the flash off on a cannon power shot a400 camera
Your menus will have options to be able to turn off the flash in certain modes.
The camera also has external buttons which will turn the flash on or off. Read your user manual.
The button which has the SET inside has four selectors. The right selector has a flash on/off button to turn the flash on or off. The flash usually will flash when set to flash all the time and not in AUTO mode. The AUTO mode may not allow you to turn off the flash. You probably have to choose another mode to allow the flash to be turned off.
If you do not have a user manual, here is a link to a free pdf download: User manual Canon A400
2answers
When I try and turn on my phone it flashes and doesn't turn on just keeps flashing on and off.
Flash
Where the OK button is there is a circle around it. On the left side there is a pic of a flash. You have to turn on camera then turn off flash by pressing the button on the left (flash) til your display shows a flash with a circle around it in the top left corner. Now the flash will not come on.
2helpful
2answers
I can't remember how to turn the flash back on to auto flash?
  folloe these steps
camera<settings <Flash< turn it on .    or camera<more<flash<turn it on
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
