HOW i CAN TRANSFER PHOTOS FROM CAMERA TO MY LAPTOP
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
SOURCE: Transfer of photos on camera without memory card to memory card
take out the memory card and plug the camera to your computer and it should show that way and save them. hope that helps..
SOURCE: having problem transferring photos from camera to pc
connec the usb cable to ur pc and then open my computer.
you shall see a removable disk double click that.
then click on the folder called DCIM and you can find all ur pics there.
select whichever you want and drag and drop them to the location you want them on the computer.
issue resolved.........let me know if u have anymore queries.
also you dont need the software installed only the drivers for the usb cable need to be installed
SOURCE: I can't transfer the photos
Install your camera driver using the driver cd with camera.Use data cable connect camera and the computer with usb port.Now the camera can open using computer now import your images to computer
SOURCE: how to transfer photos from the camera if without
Hello and welcome to FixYa
To transfer the photos, Follow the given instructions:
When
you are looking at the back of your camera, on the bottom right side of
it there is a little flap that you can lift open to reveal the USB
port. You will need the proper USB cord to connect your camera to the
computer, it should have come with this cord. The camera must be powered
ON when you connect it to the computer. Windows should then
automatically give you a popup asking what you want to do. Choose the
Open Folder option, as shown below.
You
will then see a window with all of your picture files. Copy them all by
pressing Ctrl+A and then Ctrl+C. Then open the folder on your computer
where you want to save them (such as My Pictures) and press Ctrl+V to
paste them.
The other option you have is to purchase a card
reader that is compatible with a Sony Memory Stick Duo (which is about
half the size of a Memory Stick), With
this device, simply insert your card into the reader, then insert the
reader into the USB port of your computer. You will get the same Windows
popup as shown above, and you can follow the same steps to copy your
photos onto your computer.
I hope this will be helpful for you.
Best of luck, Anymore help, i am here to help.
Thanks and Keep Visiting FixYa
