SOURCE: Delta side spray replacement
Delta makes sprayers to match the faucet design. Functionally they're about all the same. GO to theirr web site: http://www.deltafaucet.com/customersupport/index.html
If you don't know your model number you can use their wizzard and identify your faucet model. Then go to the parts section. One difference on the number you listed is I believe on comes with the mounting fitting that attaches to the sink. Some don't have it if they go through the faucet base itself.
Delta faucets have lifetime guarantee, I'm not sure if that includes the sprayer. (I doubt it)
SOURCE: delta 470 sprayer hose....have old one out. New
i think the heavy wight it loos or its out of the house so check that out
SOURCE: Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
SOURCE: Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
SOURCE: I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
