SOURCE: baby lock ellure plus
HI,
Here is the solution:
leave the USB plugged in then turn off your computer and
back on. Seems like it recognizes it at that point. Once you unplug your device you have to do the same routine to get it to recognize it again.It will recognize it as "removable disk F"
Goodluck,
Please don't forget to accept the solution as fixya.
SOURCE: Baby Lock Ellure
I HAVE HAD THIS HAPPEN SEVERAL TIMES AND WHEN I WOULD CHECK THREAD IT WOULD BE OK, MOST OF THE TIME HOWEVER, IF I COMPLETELY UNTHREAD IT AND RETHREAD IT THE PROBLEM IS SOLVED. I HATE IT WHEN THEY DO THIS MUST BE A PROBLEM WITH ALL OF THEM
SOURCE: Babylock ellure safety device
I have the same problem, I have done what the book says but no luck yet. Have you figured out what happened? And do the experts really check the questions? Cause I asked a question awhile ago, and no answers. Help!
SOURCE: I need to service my Baby Lock Ellure sewing
All you do is clean the bobbin area - no oiling unless stated in the maintenance section of the manual.
If you do not have a manual, the Babylock website may have a download.
Testimonial: "Helpful information - easy as could be!"
first change the needle
rethread the machine top & bobbin
use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is not warped or damaged
make sure the bobbin is not to full
make sure the bobbin is inserted correctly & turned correctly in the
bobbin case
make sure there are not any burrs on the needle plate
make sure there are not any burrs on the bobbin case
