Whirlpool LHW0050PQ Front Load Washer Logo
A
Anonymous Posted on Jun 08, 2014
How to change a belt on Aeg 56800 - Whirlpool LHW0050PQ Front Load Washer
I have a 14 yr old AEG 3200 dryer. The drum has stopped turning.Could this just need a simple belt replacement or wld you recommed a new dryer. Thanks
If you can hear the motor run when activated replace the belt. You should check or have checked the rollers that the drum is supported by. Check the belt tension-er replace if worn. While the unit is disassembled the rollers are easy to replace.
Vacuum all loose lint out from around the motor while disassembled.
These simple older machines are reliable and very durable and only have a few moving parts.
Hope this helps?
AEG LAVATHERM 60750225500 Tumble Dryer Section Spare Parts Diagram
Jun 21, 2017 • AEG Dryers
Hi I have a dryer aeg 56800, when switched on for 11 beeps and light so they can help me?
Have you tried cleaning out your dryer vent? A Clogged Dryer Vent will lead to dryer malfunctions. You may want to look into a Dryer Vent Cleaning
Apr 20, 2016 • AEG Dryers
How do I replace the belt on the AEG lavatherm T3
Again open the front panel and look for the tech sheet, it will give you the steps. You can try to google your model with tech sheet on the same line, and a lot of times can find it. But why do think you have a bad belt?
Dec 20, 2014 • AEG Dryers
AEG Lavatherm 33600. I replaced the belt
the felt is to stop rubbing you can get it from a craft shop. I changed the felt bearing cover with a nylon type washer works better and now don't get static discharge when taking out the clothes. under a 5ver for the lot.
Sep 30, 2013 • AEG Dryers
Not spinning fast enough
you cant on them you probly need new brushs in your moter that is what would slow it down or your bearing might be on there way so if there is no noie cuming from the drum then its just brushes ok
AEG Lavmat 835 washer will not reach spin speed
Possible fault in the motor , the bearings the drive belt or there is friction on the drive shaft.
Please check these links for tips:
Bearings check
Drive Belt
1helpful
Need a diagram on how to refit fan belt
Like a lot of people...you didn't post your engine size....so out of these 11 photos, please choose the correct one for your application:
Accessory drive belt routing—1.8L (AEB/ATW/AWM) engines
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines with A/C
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines with A/C
Accessory drive belt routing—2.0L (ABA) engine without A/C
Accessory drive belt routing—2.0L (ABA) engine with A/C
Accessory drive belt routing—2.5L (BGP) engine with A/C
Accessory drive belt routing—2.8L (AFP/BDF) engines
Accessory drive belt routing—2.8L (ATQ) engines
Accessory drive belt routing—4.0L (BDP) engine
2answers
How do I understand the dial on the dryer AEG lavatherm 335?
it should show a full sunshine for high and half a sunshine for low
Jun 23, 2009 • Dryers
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
