KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
A
Anonymous Posted on Jun 08, 2014
Why is my Kitchen aide microwave, not heating?
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 13, 2008
SOURCE: need to replace door handle
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 06, 2009
SOURCE: How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Let us know if we can help further.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 04, 2009
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Anonymous
  • 612 Answers
  • Posted on Sep 03, 2009
SOURCE: kitchen aid microwave model# khms 147 hss-1 runs but doesnt heat
Your problem is your mag tube (Magnatron) you can go to www.partsselect.com and your part number is PS2352604. Their price is $123.44. I work on micro waves myself and have found that if one isn't a built in over the stove like yours, they are not worth repairing because you can buy one cheaper. If this unit is not real old and you can replace this parts yourself it might be worth fixing bit if you are going to have it repaired, it might be cheaper to replace it. Good luck.
P.S. If you open this unit up. Make sure you bleed the capacitor off, this is one that will knock the _ _ _ out of you if you ground it by touching it. Bleed it by using screw driver to short capacitor to ground or case.
Please rate this solution
woobie dog
woobie dog
  • 1273 Answers
  • Posted on Feb 08, 2011
SOURCE: How to replace light bulb
Hello, W/D here.
Sorry it took so long to get back to you, the internet crashed, and I had to look at a few things, just to be sure.
It turns out that your oven lamp replacement is very close to an Advantium lamp replacement.
You have to remove the microwave from the wall cabinet, and remove the sheet metal surround. Then, you can access the bulb for replacement. The part # for the bulb is # 4375348 (whirlpool). These are available at Lowe's, H/Depot, or any appliance parts supply store.
I have an Advantium, and after two replacements, I cut a hole in the sheet metal, and fitted a metal "peep-hole" somewhat larger than I needed to get to the screws holding the bulb, and I screwed the cover plate down to the sheet metal. The result was that I wound up being able to slide the microwave out about 6" and change the bulb as opposed to having to remove the entire microwave from the cabinet holding it.
Hope that this is just what you needed.
Respectfully yours, --W/D--
Please feel free to rate this solution! Thanks.
Microwave Kitchen aid KEMS308SSS04 not heating. Does this midel have a acapacitor
probably not. if not heating, either power is not getting to the m.w. emitter or it is burnt out. either way, it is not something you want to screw with. cut the cord, recycle it, buy a new one.
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
1helpful
Kitchen Aid microwave over will not heat
Common cause of this problem is transformer fuse blown.check the fuse.if fuse is ok, then replace magnetron
1helpful
Kitchen Aid microwave KHMS105EWH-0: I started to heat a cup of coffee, it momentarily interrupted power to the kitchen, fluorescent lamps went out, then slowly came back on. More below.
Because of the loud snap you are hearing, my guess is you have something shorting out in the high voltage section of the microwave. I'm surprised it is not blowing the internal microwave fuse yet. Average repair cost depending of what part it going bad is approximately $150 to $200. Considering the age of your micro my suggestion is put the money towards a new one.
Kitchen aid microwave will not heat
first check the fuse if cutoff, replace it. if ok, then check for any broken wire. if all connections are intact, then test the heating element for continuity, if no continuity, then the element is bad and needs replacement. try these steps
Kitchen aid microwave kbms1454rss clicking
Yes! from the information, you probably have one or two defective door switches. Parts need to be replaced for normal operation.
I have kitchen aid microwave modelkcms185jss starts runs fine but does not heat food at all.
Does not heat food means a problem on magnetron tube and fuse blown in high voltage area. Have it replaced and it will heat again.
I hope I answer your problem.
My kitchen aid over the range microwave Model No; KHMS105EWH-0 stop heating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
