Question about One For All URC-9800 LCD Remote Control
Programming rc-017 vizio remote control
Programming
Can I use your remote universal Llz414
Here is the Remote info
  • VIZIO Universal Remote Setup ' VIZIO www.vizio.com/remote-setup Point the VIZIO remote control at the ... Click the following link to view a complete listing of codes to program your universal remote. ... TV; Audio; VIZIO ...
  • Universal Remote Codes - Vizio cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf · PDF file UNIVERSAL REMOTE SETUP ... Find the programming code for your TV (or device) in the ... Point the VIZIO remote control at the device and press
  • Vizio Universal Remote Codes - TVremoteCodes.net tvremotecodes.net/vizio.html Vizio Remote Codes for TV, DVD, VCR, ... Uverse Remote Codes; Comcast Remote Codes; Dish Remote Codes; Universal Remote Codes; Apple Remote Control; ... VIZIO ...
  • The company started in 2002 as V Inc. by William Wang, Laynie Newsome, and Ken Lowe with $600,000 and three employees. In 2006 the revenue was estimated around $700 million, and in 2007 it was estimated to have exceeded $2 billion. VIZIO is known for aggressively pricing their HDTVs against major competitors.[2]
  • On October 19, 2010, VIZIO signed a 4-year contract to sponsor college football's annual Rose Bowl game in Pasadena, California, beginning with the 2011 Rose Bowl presented by VIZIO and ending with the 2014 VIZIO BCS National Championship Game.[3] When the Rose Bowl contract ended, VIZIO signed a contract to sponsor the Fiesta Bowl making the official name the VIZIO Fiesta Bowl.
    As of 2012, VIZIO has over 400 employees.[4] About half work at its headquarters in Irvine, California, in engineering, design, sales, and operations, while the other half are employed at a call center in Dakota Dunes, South Dakota.[4][5]
    VIZIO also manufactures its products in Mexico and China under agreements with ODM assemblers in those countries.[6]
    Her eis
    Dec 31, 2015 | Vizio L32 32 in. LCD HDTV
    There is no TV button to press on rc-017 remote, setup instructions say press on tv button till led lights up.
    If you mean the Coby RC-017 remote, it is not a universal remote that can be set to control any TV or other device. This remote will only work with the TV for which it was originally programmed. I believe it should work for a TF-TV1511, if both the remote transmitter and television IR sensor are working. Assuming you have the correct TV, try just pressing the power button.
    I hope this helps.
    (I suspect you found the directions for the Coby Universal Replacement Remote which controls several devices.)
    Dec 01, 2015 | Televison & Video
    How do you program a vizio rc-017 to a Philips smart tv
    Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
    http://remotesearch.blogspot.com/
    http://electrohelponline.blogspot.com/
    Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy
    Feb 08, 2015 | Vizio Televison & Video
    Manual vizio rc 017
    On the front of the remote underneath the 3D, zero and minus keys, you can see a line that slightly arcs. Turn the remote upside down. The power button should be in the bottom left corner. Place both thumbs just above that arcing line and firmly push up.
    Sep 02, 2013 | Televison & Video
    I need a code to operate a Vizio Blu-ray player, VBR231, with Dish Network remote control. Thanks! ctelschow@msn.com
    HERE ARE A FEW SUGGESTIONS TO LOCATE A SUITABLE CODE FOR YOUR
    VIZIO BLU-RAY PLAYER, MODEL VBR231
    1. HITATCHI CODES ~ VIZIO CODES
      WHICH MEANS YOU SHOULD TRY HITACHI BLU-RAY PLAYER CODE(S) LISTED IN THE DISH NET RC MANUAL.
    2. FROM DISHSUPPORT.COM FORUM:
      Scott Greczkowski
      DISHSUPPORT STAFF
      hances are the 5.3 remote will not control that Blu-ray player. What will work however is a DISH Network 21.0 remote which not only has a better IR code database, but also is an IR learning remote. This means if the code is not in the remotes database you can teach it to learn all the functions of your Vizio Remote.The DISH 21.0 remote will also work fine with your 622/722.If you can't find a 21.0 remote then please PM me and I can tell you where you can order one. They may also be available from DISH Network directly.
    *Configuring your devices with a "UNIVERSAL" Remote can sometimes be a stressful and frustrating experience. But it doesn't hafta be!*
    Here are a few general
    GUIDELINES TO UNIVERSAL REMOTE CODE SUCCESS
    • READ THE ENTIRE INSTRUCTION MANUAL THAT IS INCLUDED WITH YOUR UNIVERSAL REMOTE (OR DOWNLOAD ONE FROM THE VENDOR'S WEBSITE)
    • USE THE REMOTES "AUTO CODE SEARCH" FEATURE TO FIND A MATCH TO YOUR DEVICE (IF A DEVICE HAS ONLY PARTIAL FUNCTIONALITY e.g. CHANNEL +/- WORKS, BUT VOLUME +/- DOES NOT= CODE IS NOT THE BEST MATCH FOR YOUR DEVICE)
    • PRACTICE PROGRAMMING (AN)OTHER DEVICE(S) IN YOUR HOME TO MASTER THE PROCESS OF PROGRAMMING CODES WITH THEIR MATCHING DEVICES USING YOUR UNIVERSAL REMOTE CONTROL. TRUST ME, IT BUILDS CONFIDENCE, ASSURES THAT THE RIGHT PROCEDURE IS BEING FOLLOWED IN ORDER TO PROGRAM THE REMOTE, AND PROMOTES EXPLORATION OF THE "UNIVERSAL" ASPECT OF THE CONTROLLER.
    Apr 02, 2011 | DISH Network Televison & Video
    Problem programming Remote RC-U49C+ with Samsung LN22A450 22''TV
    Have you tried:
    Samsung – 044, 070, 074, 192, 007, 020, 040, 119,
    129, 015, 016, 017, 023, 031, 090, 107, 108, 134,
    147, 151, 153, 386, 411.
    May 24, 2009 | Televison & Video
    Finding remote code to control my vizio tv
    In my Vizio manual it says to try 1758 or 0178. I tried both and the 0178 worked for my rc-681m remote
    Nov 25, 2007 | Vizio GV42L 42 in. LCD Television
    One For All URC-9800 LCD Remote Control Logo
    369 people viewed this question
    Top One For All Televison & Video Experts
    Joe Negus
    Joe Negus
    Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
