SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
SOURCE: Vertical Flashing Lines on Toshiba 42HP84 Plasma 42"
troubleshooting PCB's of certain electronic units require advanced technical skills. no service manual of any source would provide specific solutions. the best you can get are schematic diagrams. if your field of expertise is not related to electronics, i suggest you let the technicians handle the problem for you. every shop have their repair cost qoutations. just be sure to ask for warranty of their repair. goodluck!
SOURCE: Faint black lines running vertically
did you try unplugging everything and resetting your cable box. then plugging it back in,
i got some faint boxes yesterday and that did the trick
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
SOURCE: black line
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
