SOURCE: element 32" flat screen tv has cracked screen
Sorry to say, when the display is broken you're best off looking for a replacement TV.
There isn't any way to repair a cracked display except to replace it. You can try a Google search or check websites like shopjimmy.com that sell parts removed from junked sets. It's almost impossible to find replacement displays (unless you are a warranty servicer and get them right from the manufacturer) since most TV's are junked because of broken displays. And if you do find a display, there are still potential problems. Besides the cost (the display is the most expensive part, most of the set's cost), you need to be sure the display is exactly the same part as the one you're replacing. The same model of TV can use different displays depending on when and where it was made, and there may be differences in other parts in the set as well.
SOURCE: every so often my element flat screen tv model fx
turn off close caption all the way in menu
SOURCE: Our 32" flat screen Element
Panel screen is broken, need be replace. Price is too high ( new). Maybe is not worth repair.
SOURCE: I have an Element 32" flat screen tv and when I
Possible there is fault on the motherboard as the processor seems to swtich on but there is no drive from the mother board. Unless a proper voltage check is done the voltage to the drivers cannot be confirmed.
