Vizio P50HDTV20A 50 in. Plasma HDTV Logo
A
Anonymous Posted on Jun 07, 2014
How to reset
Want turn on
How to reset uniden GMR1938-2 radio
To reset the Uniden GMR1938-2 radio and turn off monitor mode, you can follow these steps:
1. Turn off the radio by pressing and holding the Power/Menu button until the unit powers down.
2. Once the radio is turned off, press and hold the Menu button.
3. While holding the Menu button, turn on the radio by pressing the Power/Menu button. Keep holding the Menu button until the display shows the Reset prompt.
4. Use the Channel Up or Channel Down button to navigate to the Reset option.
5. Press the Menu button to select the Reset option.
6. The display will show a confirmation message asking if you want to reset the radio. Use the Channel Up or Channel Down button to select "Yes" and press the Menu button to confirm.
7. The radio will reset to its factory default settings, including turning off the monitor mode.
After performing the reset, the monitor mode should be turned off on your Uniden GMR1938-2 radio. You can now use the radio normally without the monitor function active.
1helpful
How do I reset service indicator on a vauxhall astra 2013?
• Turn Ignition Off
• Hold Trip Reset In
• Turn Ignition On
• Still Holding Trip Reset wait for three dashes
• Turn off Ignition
• Turn on Ignition to confirm
What is the correct reset for Yamaha P 85 Digital Piano?
Reset Instructions:
1) Try a partial reset by holding down the last white key while turning the unit ON.
2) If you haven't recorded any performance(s), for a full reset, hold down on the last white key AND THE lst three black keys while turning the unit ON.
Ink absorber is full
Resetting your canon printer will solve your problem. follow these instruction to successfully reset and fix your problem
1. Turn off your printer
2. Hold the Stop/Reset button then press the On/Off button
3. While holding Stop/Reset and On/Off button press Stop/Reset button, it will go to service mode.
4. On Service mode press Stop/Reset 4 times (this will reset ink absorber problem)
5. Turn off and then turn on your printer.
2helpful
2answers
Maintenance Lamp
Here's how you reset your maintenance light.
To reset the light,
Turn the ignition on
Make sure the odometer displays "ODO"
1.Turn the key off
2.Press and hold down the same button you use to get to "ODO"
3.Turn the key back to ON ( while still holding down the button)
4.Hold the button in until all the flashing lines on the odometer go away and the bunch of "000000" shows up and the maint reset light will turn off.
Your'e done.
If this doesn't work, you would have to try it on "trip A" instead of "ODO".
6helpful
3answers
How do i switch off service now light on my vw golf 53 plate
Courtesy www.synthetic-direct.ca:
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button “A” located below the speedometer. Turn off the ignition while holding the button. “OEL” will display on the indicator. Press and hold the lower digital clock reset button or the analog clock reset button “B” until five dashes appear in the display.
If needed, next press the odometer reset button until IN 01 is displayed and then press the clock reset button until five dashes appear. If needed, next press the odometer reset button until IN 02 is displayed and then press the clock reset button until five dashes appear.
To exit reset mode, turn ignition switch on and when IN 01 appears, turn ignition off.
46helpful
6answers
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
9helpful
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
2answers
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
