SD cards are too small (not sufficient memory space) for your files. You need to use USB Flash Drives. Cost is dependent on the storage space you need. Always REMOVE Cards/USB Devise with the EJECT Command. Do not simply pull them out by hand because they are sensitive to Static Charge and can blow out.
It may be too full. Check how much free space you have. Try to have approximately 3GB free. Delete things that are easy to replace like apps, or music you can download again.
That system warning relates to available application space. For some reason Archos only devoted ~128 MB for applications, so you can fill that up pretty fast. You'll need to:
uninstall applications (settings, Applications, Manage Applications, then select and uninstall some)
or
move some applications to "internal storage", this transfers some of the space they're taking to the internal storage on your Archos. Again you'll go to Settings, Applications, then Manage Applications. From the list of applications select some of the larger ones and you may see a "move to internal storage" option. Some apps have this, some don't.
