120801
Turn on your printer and raise the lid or press the cartridge changing button.
Wait for the cartridge carrier to slide out.
Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Open the top panel of your inkjet printer. You should be able to access the ink cartridges once the top is open. Some printers will reposition the cartridge carriage to provide you better access.
Remove the old cartridge from the carriage. Depending on the printer, you may need to press down on the cartridge and then pull outward to remove it. Other printers may require you to lift the cartridge out of the printer.
Unpackage the new replacement cartridge completely. New cartridges will often include plastic strips and protective packaging that must be removed before you can insert the cartridge into the printer.
Insert the new cartridge into the printer. This will be the reverse of removing the old cartridge.
Close the top panel of your inkjet printer and allow the printer to detect the new cartridge. You should now be able to print using your newly changed inkjet cartridge.
