SOURCE: Do I use regular or premium gas for my '96 Honda VT 1100 C Shadow
You always want to use the highest octane gas u can find in a motorcycle engine .... 91 at least
SOURCE: What kind of oil does my honda shadow 750 aero
As this is a 4 stroke bike, it will take 4 stroke motorbike oil, you can buy this from any good garage
SOURCE: how to change sparkplugs on honda shadow motorcycle
VT1100 has two spark plugs per cylinder, the sparkplug caps are snap-ons so they're fairly easy to remove. You need a spark plug socket wrench to remove and replace the spark plugs.
SOURCE: I would like to know how to lower my honda shadow
When lowering bikes, we usually lessen or cut the shock absorbers (front and back).
Accessory places have lowering blocks, they are just a small metal
accessory that move the bottom of the rear shocks to the rear and down,
I think you get 1.5 inches from them. Then you need to cut or get shorter springs in the front, either will probably make the ride stiffer in the front.
SOURCE: 2007 honda shadow aero vt750 will not stay running
You probably have some gelled gas in the carbs. Take off the fuel line going into the carbs and spray some carb cleaner directly into the bowls. This may take care of a minor clog. If this does not work , you will have to take the carbs off and clean the slow jets and slow circuit passageways before the bike will idle normally again.
