Question about Amana PTH123B25AJ Heat Pump Air Conditioner
How to service with refridgerant - Amana PTH123B25AJ Heat Pump Air Conditioner
    Genius:
  • Amana Master
  • 1,363 Answers
You would have to install line tap valves.
Posted on Sep 08, 2015
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I purchased a Kitchenaid Refridgerator 6 months ago. I changed the filter at the bottom about 3 weeks ago. Ever since then, my refridgerator has a bad odor. I have completely cleaned the refridgerator and...
If you purchased this machine NEW 6 months ago, everything on it is under warranty. You should contact the selling dealer to verify you are entitled to a free service call. Changing the filter is routine maintenance and in no way should affect the warranty.
Oct 25, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Wine Refridgerator - Class Action Lawsuit
Franklin Industries (Franklin Chef) has filed for bankruptcy protection as of 9/11/09:
http://www.franklinchef.com/important.html
Looks like we are out of luck
Sep 09, 2009 | Franklin Industries FBC360D Beverage...
I have a wide by side maytag plus refridgerator 5 years old-
change the thermostat as well as a technician if i see the heater is ok i change the thermostat and defrost timer together the thermostat  is iffy(if thats even a word) it works sometimes sometimes doesnt unless they obviously bursted but if they are in normal shape doesnt mean they work properly because of the fact that they work sometimes sometimes dont
feel free to ask any questions
Jun 08, 2009 | Refrigerators
PAC L90 LT thermostat not working, unit icing over
No that would be either a dirty filter/coil ir low refridgerant if it's freezing in cooling mode.
Clean/replace the filter, clean the coil and if it keeps doing it, have a technician who is EPA certified for servicing systems with refridgerant to look at it/add refridgerant.
Mar 24, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Dead short of refridgerator
This is a problem that most likely will require a qualified service technician to resolve for you. for SAFETY SAKES DO NOT LEAVE TEH UNIT PLUGGED IN. and call a reputable company in your area. thx peyton
Jan 28, 2009 | Whirlpool Refrigerators
Hotpoint refridgerator model csx27d
Friend,
ngfam1 At your service!
NEEDS SERVICE AND PARTS. PERHAPS ALL NEW ICE MAKER!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Aug 31, 2008 | Hotpoint Refrigerators
MY refrigerator is running but is not getting cold.
This has several issues you might need to look into.
First, your refridgerator you selected shows it is a front load washer. I know that can't be right.
Second. Your temp setting. It should be set in a manner that allows the humidity to exhaust out.
Third, Your refridgerator compressor is about to go out.
Fourth, you are placing alot of warm food into refridgerator, and holding the door open too long. This sometimes shuts the compressor off.
Also peer behind your refridgerator. Is there alot of debris, dirt, brooms, etc behind there. If so clear it out completely.
On the front of some refridgerators there is a grill that can be removed carefully. You will see cooling fins on the inside of this.
Very very gently remove the dirt and debris off of this. The fins bend very easily, so becareful.
At the same time check drip pan, and empty if needed.
If none of these things seem to do the trick, contact a service technician, something tells me it is your defrost sensor, or compressor.
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
47 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
WatsHVAC
Level 1 Expert
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
