Bottom oven goes on then turns off
SOURCE: Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
SOURCE: 326B1230P001 GE double oven
You can go to http://www3.sears.com/ or http://www.appliancepartspros.com/. You will need the complete model # from the sticker on the oven. The # listed above is not correct. It looks like a serial #.
SOURCE: installing ge profile double oven
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
SOURCE: 326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at [email protected] for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
SOURCE: GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
