LG LRFD25850 French Door Refrigerator Logo
A
Anonymous Posted on Jun 06, 2014
Why is there water on floor under unit ? - LG LRFD25850 French Door Refrigerator
Water on floor under freezer unit &sheet of ice on floor of freezer.
It probably has a water leak, perhaps the water hose or a connection.
1helpful
Washer bouncing while spinning
Make sure the unit is leveled and on a solid surface. You may have to brace the floor up under the washer if the floor is too flexible. To test this place a glass of water on the floor in front of the washer. if the water vibrates and ripples in the cup the floor is weak. Manufacturer's came up with this test.
Jan 22, 2014 • Dryers
1helpful
The unit is on a hardwood floor and there is water damage to the floor. The unit appears to be dry now. Could it have a leak that can't be seen?
The potential for water leaking to the floor is probably still there. Open the door of the unit, look in the back and you will see a white plate; that is the evaporator. When the unit is running, there is a light frost that forms on the front and back surface of the evaporator; sometimes the frost can get a bit thick because of air laden moisture infiltration or the frequency of door opening. That frost eventually will melt and drain from a drain hole right underneath the evaporator. If that drain hole is plugged up, water will eventually leak out from under the door. Keep that hole clean and patent and also check the state of the water collecting pan underneath the the unit. That might solve your water problem.
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
1helpful
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Water on the floor under the freezer side of unit
It happens to all those old refrigerators. There is a shield separating the drip container and freezer through a small hole. Check if it is blocked. This won't do much of the work and may not be stopped even if you do something. If you can, have a new refrigerator.
Have Liebert DH125 down flow unit with one (1) alarm
ive worked on many liebert units therss a water sensor on the bottom of the unit basicly the units pan try to find that switch and mayb cleen under it or if it s aprob depinding on the age
1helpful
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 • Dishwashers
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
2answers
Water coming into refrigerator
Evelyn,
More than likely (I can't be sure from here!), your icemaker "motor module" has failed. This module controls the amount of water that goes into the ice tray. If the timer fails, the water valve can stay open. Also, if this is a new unit, or a used refrigerator you just installed, all you may need is to reset the timer on the motor module. The icemaker must be removed to do that. The tray fill time varies with the local water pressure. If your water pressure increases for some reason, the time must be shortened to avoid overfilling the tray.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
