Have tried three different memory cards. Can't take photos. Can't download photos. Photos appear with card reader, but I can't download from that either...!!!???
SOURCE: Unable to download through usb
I had the same problem and realized that my computer wasn't recognizing my camera. I went through my device manager and looked under portable devices, I could see that my camera had an error in its driver, so I right clicked on my camera and uninstalled the driver for my camera, and unplugged and plugged my camera back in. It instantly recognized my camera and reinstalled the driver.
SOURCE: Camera won't upload pictures/memory card isn't processing images
I am having the same problem. the program i have got is does not work with the camera. than i tried it on a different computer, which worked perfectly.
SOURCE: When i insert my memory card it says
Is it a new 4GB memory card? If so that might be your problem. The card would likely be an SDHC card, and your camera was designed well before the SDHC format came out. Your camera can only use standard SD cards (2GB or less).
But if the card is less than 2GB, it could have become corrupted. In this case you could try formatting the card in the camera to see if this would rejuvenate it. This will also erase the card. See this post if you wish to first recover those pictures.
Finally, if this is occurring with multiple cards, and is also saying "card locked" even though the tiny slide switch is in the unlocked position, then see this post for a possible remedy.
SOURCE: need to recover deleted photos
You can connect camera's memory card to computer, then download this picture recovery program which is outstanding among all picture recovery software.
http://www.001-software.com/picture-recovery/
