Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
R
Randy Posted on Jun 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix a water port?
There are 2 water ports for water to exit the wave runner. One works but the other does not.
neil
Level 2:
Scholar:
  • Expert 151 Answers
  • Posted on Jun 06, 2014
neil
Expert
Level 2:
Scholar:
Answers
151
Questions
0
Helped
50471
Points
288
Possible seized water pump
the one that is not working
follow it back to the source look for blockages
but personally i cannot see a blockage stopping all water coming out
so i would look more at the water pump
Kenneth Nash
Level 2:
New Friend:
  • Expert 48 Answers
Kenneth Nash
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
4888
Points
117
Check pump for port.
tip
IMR - Inlet Manifold Runner valve
1.10) IMR- Inlet Manifold Runner valve (actuator)
What is it? The inlet manifold consists of a plenum chamber onto the front of which is mounted the throttle . Extending from the plenum is a series of moulded pipes called 'runners' curve round to the intake ports on the cylinder head. In some instances there are two intake ports for each cylinder fed by slightly different lengths of runner. When the engine is at low revs the longer pipe works well. However at higher speeds the shorter length of the alternative runner is better suited. To cater for this the shorter port, which is normally shut off at low engine speeds by a plate (very similar in operation to the throttle plate), is opened by a motor or solenoid. The shorter runner is usually opened in addition to the longer runner and not as a substitute. The opening of this additional shorter runner is done by the IMR.
Where is it located? The IMR valves are located in the throat of each inlet port and the controlling motor is located at the end of the interconnecting shaft.
How does it work? At a predetermined engine speed (>3000rpm) the ECU sends a voltage to the IMR that snaps open the additional inlet portsto boost power output. It does this by either a) directly with an electrical motor or b) it opens a solenoid valve and allows vacuum, sourced from the inlet manifold, to act on a diaphragm to rotate the valve shafts.
Symptoms of a faulty IMR
Associated OBD2 error codes DTCs: P1500 - P1599
  • Power reduction - If the IMR fails to open in the upper rev range the engine will seem to lack any (power) 'head-room'. The engine will still operate but the usual additional power boost in the upper rev range will be absent.
How to Check? Visually check the action of the action of the actuator in response to increasing engine speed.
How to Fix? Check the wires and connections. If the device uses a vacuum, check the tubing for leaks. If the IMR unit is faulty replace it.
NEXT 1.11) EVAP - Fuel Vapour Evaporative Control System
NEED WATER ROUTE DIAGRAM PLEASE ON WAVERUNNER2
not really sure what a wave runner 2 is, theres a 3 or are you talking about the original style Yamaha? is it a 500 or 650?
1helpful
ABOUT HOW MUCH IS TO UNLOCKED A 2 STROKE WAVE RUNNER 1200XL LIMITED
no idea on price but this sort of thing is used in salt water so although a new set of rings and a quick hone of the bore will sort it and maybe a new crank bearing as its obvious someone didnt put oil in with the petrol but the problem i have had with a lot of these fun machines is that getting the engine apart after salt water use is ?well lets just say difficult
My 1992 yamaha waverunner iii 650 is taking on water?
I know this sounds obvious, but make sure the plugs are screwed in.
usually 2 of them at the back of the waverunner.
i know i forgot to put them in one day and by the time i parked the truck & trailer it took on so much water the motor was half submerged.
Hurried and pull the truck back and got it out and let her drain iout the plugs, then fired it up.
anyhow, if thats not it then your hull must be cracked and leaking in, take seat off at the ramp and see if you can see where its coming from, if you don't notice anything, then its coming in through
the ports at the top of the wave runner under the steering assembley housing, those tubes are made to direct the water to the bottom, if you have an auto matic bilge pump, make sure that is working or it won't pump out the water like it is supposed to.
hope that helps
Big Al
2helpful
I need to config a hp procurve 2610 with a data and voice vlan to work with my mitel.
hostname "Switch1"
qos dscp-map 101110 priority 6
snmp-server community "public" Unrestricted
vlan 1
name "Data_Vlan"
untagged 1-28
ip address 192.9.180.19 255.255.255.0
exit
vlan 2
name "Voice_Vlan"
ip address 10.9.180.5 255.255.255.0
qos dscp 101110
tagged 1-28
voice
exit
Program the port that the PBX is in as a untagged port on Vlan 2
1helpful
Logitech wave cordless keyboard won't work
Do you have the piece that plugs into the computers usb port and changed the batteries, or charged it, I have a logitec on 2 machines, you either have a receiver that plugs into the laptop/desktop, or a device that takes up to 3 wirelwss accesories that plugs into the usb port, they both take batteries in the mouse and keyboard. you can download the software for your keyboard on the logitevh wesite, at www.logitech.com
4helpful
I just purchased a used 2001 Yamaha XL800 waverunner
Yes. Those are called power valves. The purpose of those valves is they create a variable height on the exhaust ports. This is desirable because it gives you good low RPM power by keeping the height of the exhaust port low, and as the revs of the engine build, the exhaust valves raise up which opens the exhaust port up and allows the engine to create more peak HP due to the higher exhaust port and larger area of the exhaust port.
There is no additive that will clean your power valves. They have to come out.
Water does not drain from the machine
The only way for water to be exhausted from the Eurotech washer unit is for the water pump to function correctly. Check for operation of the water pump which can be heard with a faint hum during the water exhaust cycle. Also check to see if the drain port is blocked etc eg with a childs sock. To check for this open the lint filterdoor,remove the lint filter and using an inspection mirror look around paying attention to the 2 ports inside the filter cavity. If filter ports are clear then suspect the water pump. If you can hear the water pump working but the water is not exiting your washer then it is likely the 4 prong impeller inside the water pump has sheered off its shaft within the pump. Change pump and this should solve your problem.
Printing on a Canon Image Runner 5000
go here and download the PCL5 driver for Windows XP (NOT THE 64 BIT version though):
http://www.canon.ca/english/index-softwaredownload.asp
The driver is the same regardless of the port. Just select "local" port when setting up.
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
