SOURCE: model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
SOURCE: Westinghouse LTV-32w1 32 in. HDTV-Ready
The fly back unit as failed resolder the flyback side,most of problem is cause by loose contact only, or if your not tech person need to get it serviced it would cost 50 $ to 100 S.............
SOURCE: Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
SOURCE: Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
