SOURCE: I get F4 (Freeze control failure) on my Dometic Penguin A/C
This is from the service manual:
16. SYSTEM RESET
a. Turn the ON/OFF switch to .OFF. position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to .ON..
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection
Hope this helps
SOURCE: problem w/ dometic penguin a/c. upgrade kit?
You know what, I have never ran into that yet in 15 years, so I think your best bet would be to go to, (dometicusa.com) and send then a quick inquiry to confirm, what would be required, they are usually pretty helpful believe it or not.
SOURCE: I have a 13500 btu ac dometic penguin model on pan
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
SOURCE: My 1990 Penguin unit has a leak. Can it be fixed?
Leaks can be repaired, some quite easily and others while difficult to find - and get to - prove somewhat more difficult.
The problem with 'leaks' is sometimes they are 'high pressure leaks' which are some of the more difficult ones to find.
So... the answer to your question is yes - but.
I would try and get a very experienced Service Tech to fix the leak, and one who will stand behind his work.
good luck!
SOURCE: Have a Dometic Penguin on the front of a 5th wheel...
Have you checked for frost on coils/fins when you remove filter at ceiling assy? Non-ducted I presume?
