Yamaha 12V Air Pump Logo
A
Anonymous Posted on Jun 05, 2014
2007 Yamaha FX Cruiser limp mode - Yamaha 12V Air Pump
1 Related Answer
Anonymous
  • 207 Answers
  • Posted on Jul 08, 2009
SOURCE: I am on vacation and wish to activate the L mode
u need push on the remote the l mode when the ski is not running it work just **** a alarm remote make sure the battery is good because those remotes batterys go bad quick
Yamaha YZF 600R Thundercat. How to reset limp mode please?
Question edited to add a lot more clarity.
Question moved from Cars and Trucks to model category.
First you connect a scan tool and read the codes. Then the code tells you WHY you are in Limp Mode. Then you fix whatever is wrong and the scan tool rests the code. Limp Mode is ONLY activated if something is wrong that can catastrophically damage the engine. You don't just turn it off and hope for the best.
https://www.google.com/search?q=Yamaha+YZF+600R++code+reader
My Toyota cruiser code p004 has come up, can u tell me what this code is for?
diesel turbo
re check the fuel pump pressure and filter
p004
Fuel Volume Regulator Control Circuit High
Read more at: http://www.obd-codes.com/p0004
Copyright OBD-Codes.com
If the fan goes out on a 2007 pt cruiser could it go into limp mode
Fans on PT Cruisers are a common problem. A good way to check to see if the fan is bad is to turn on air conditioner on and the fan should run, if noy then fan could be bad.
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 • Water Sport
2007 pt cruiser in limp mode. Would no freon in system cause this.
I don't think that no freon in the system would cause this. The a/c just would no work.
Waverrunner engine problem
Ditto problems with a 2007 VX Cruiser. I have two and only one is giving me problems so I don't think its the gas (since I buy for both at the same time). I see no fuel filter between the tank and the injectors. Wondering if I have an injector problem Have used a bottle of fuel injector cleaner to no avail. Additionally, I have had to replace spark plugs with relative frequency in both VX Cruisers.
I am on vacation and wish to activate the L mode on my 09 yamaha fx HO cruiser , how do I activate this from the remote?
Top Yamaha Water Sport Experts
Bob G
ADMIN Eric
ADMIN Eric
johnny bonacci
johnny bonacci
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
